A/C button gets hot... anyone else had this?
Old Nov 21, 2009 | 08:40 PM
anniemcu's Avatar
I noticed a couple of times this summer that my A/C button got hot - yes, hot - more than warm (not from sitting in the sun, either)- and reported it to the dealer when I took it in for its first oil-change. The service guy said he'd note it but had never heard such a thing. Though I haven't run the A/C since, as the weather turned cool, I had occasion to switch from outside air to recirculate the other day, to keep nasty exhaust from the vehicle in front of us from filling the car, and a little while later, when I went to switch back, noted that the A/C button, which sits directly above that lever's position, was warmer than it should be... not hot this time, but noticeably warm, and not even on. Anybody got a clue what's up??
Thanks for any input!
annie
Old Nov 21, 2009 | 09:24 PM
thefit09's Avatar
the eletrical parts behind it heat it up?
Old Nov 21, 2009 | 10:42 PM
dtmbmw325i's Avatar
I noticed this same thing but by putting my hand on the temperature selector knob. Let me know if you find anything.
Old Nov 22, 2009 | 01:06 AM
anniemcu's Avatar
That's what I'm thinking, but don't see why they would be involved in just the vent switch-over. I wonder what exactly is under there, and if there might be a short or something.
Did yours get hot, or just warm?
Old Nov 22, 2009 | 09:55 AM
reako's Avatar
Yep, I too have noticed the temperature knob gets a bit warmer than I expected. I don't think it's a big deal folks..
Old Nov 22, 2009 | 10:15 AM
dtmbmw325i's Avatar
Mine got hot. It wasn't just warm but when I put my hand on it I was like woah. I was curious if something was not right either.
Old Nov 22, 2009 | 12:31 PM
anniemcu's Avatar
Yeah, a switch or knob getting warm usually just indicates that something electrical is getting a bit warmer than it should, but having the switch or knob actually get HOT indicates it's getting a LOT warmer than it should, and it makes me nervous.
Old Nov 22, 2009 | 01:47 PM
secondspassed's Avatar
your AC tubes run just behind the dash in that area. do you have the heat on at the time?
Old Nov 22, 2009 | 03:01 PM
badself's Avatar
It gets hot because the indicator bulb behind it is incandescent, thus heating up the entire knob.
The dealer had to replace my entire switch a while back because it kept flickering on and off while the A/C was running. Every time the light flickered, it would activate/deactivate my compressor clutch. The replacement switch corrected the flicker issue, but it behaves exactly like the original in terms of how hot it gets. Short of replacing the indicator bulb behind it with and LED, there is no "fix".
grassmunk
Jul 30, 2025 09:34 PM
fitchet
May 20, 2018 10:27 PM
sy_edison
Jul 10, 2013 09:39 PM
nojjon
Apr 30, 2013 06:55 PM
TOPHER1
Dec 28, 2006 10:39 PM
