Dumb Wheel Question?
Old Dec 5, 2009 | 09:28 PM
hoss10's Avatar
I know this might be a dumb question, but here goes.
I just bought a used set of steels wheels (to use with snows) that came off the last generation Civic. (2001-5). I did phone a dealer and they said they would fit my Fit. I have a Canadian LX which comes with the Alloy 15" /5.5" wide rims. The Civic rims are 15" but are 6" wide, will this cause any problems?
Thanks for the help.
Old Dec 5, 2009 | 09:41 PM
Aspires's Avatar
I dont think 0.5" will make that big of a difference. I am running 17x7.5 and it doesnt stick out.
Old Dec 6, 2009 | 12:20 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
i don't think you'll have any problems either.
offset is the only thing i'd be worried about
but since it's an old car the offset will be
lower so offset isn't an issue either.
Old Dec 7, 2009 | 01:18 PM
B-Rod's Avatar
I bought the 14" 4x100 generic steelies for use as winters. I took off the 16" Sport rims, and I bought 14's, as the rubber was so cheap. I had bought on rim first to check for clearance issues. None, and with the rubber I bought, they are exactly the same OD as the 26" rubber.
Maybe I'll post a picture when the wife-unit gets home.
Old Dec 8, 2009 | 04:35 PM
mahout's Avatar
While Fits all have 100 mm x 4 bolt circles the hub bore and offset can change. and the 'dish' design is different too. so you'll need to mount up at least one wheel in front ( possibly rear too to check hub bore) to see if the dish clears the brake caliper. If it doesn't but is just barely interferering you can use 1/4" spacers. That also works if the hub bore is undersize. If the offset is too little so the wheel is pushed well into the outer fender arch there's not much you can do but change wheels.
Good luck. its not a dumb question either.
Old Dec 8, 2009 | 04:45 PM
Btrthnezr3's Avatar
What is the hub bore of the 09 Fits?
Old Dec 9, 2009 | 10:22 AM
nothing's Avatar
I believe it's 56.1 mm. Actually, I think most 4 x 100 Honda applications are the same.
Old Dec 12, 2009 | 11:07 AM
citabria7's Avatar
There is no such thing as a dumb question. Only dumb people who don't ask and then screw things up!
mm4
Feb 17, 2015 03:42 PM
Ciggy
May 8, 2008 09:38 PM
Quartz
Dec 9, 2007 03:55 PM
jdmjazz
Feb 17, 2007 03:20 PM
nate9
Feb 20, 2006 03:35 AM
