aim headlights
Old Dec 14, 2009 | 04:30 PM
fitisbamf's Avatar
aim headlights
ok so i got read of my fog lights but now it seems like i need to re-aim my headlights. does anybody know how to do this on a ge?
Old Dec 14, 2009 | 04:55 PM
JJIN's Avatar
the aiming nut is located near the bulb rubber seal on the headlight housing. once you pop the hood youll see a nut with metal gears when you look straight down at it. take a #2 phillips screw driver and turn. youll see an imprint of a U and D next to the hole where your screwdriver can fit, the U is for aiming UP and D is for aiming DOWN.
i hope this helps, sorry i dont have pics.
Old Dec 14, 2009 | 07:18 PM
fitisbamf's Avatar
no problem ill have to do it when im back home cuz i dont have any tools here but has any1 noticed base model headlights are different? the little cover that causes the bulb to reflect into the light has an opening on the base model but the sport doesnt. does any1 know y? or if the base models are designed for the purpose of not having fogs?
Old Dec 14, 2009 | 07:28 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
i have never seen that opening. but then again i never looked for it.
i guess next time im at the dealer i'll have to check that out.
good info thanks.
Old Dec 14, 2009 | 07:57 PM
fitisbamf's Avatar
good info thanks.
i found pictures hahahah
sport model
base model
Old Dec 14, 2009 | 08:05 PM
JJIN's Avatar
wouldnt this hole on the bulb shield cause more glare on the fit base than it does for the fit sport?
im intrigued by this difference in design, would like some feedback from some base owners with glare/no glare theory.
Old Dec 14, 2009 | 08:18 PM
fitisbamf's Avatar
a glare would create a wide angle of light (the fogs do this too) so that could make up for not having the fogs. while the sport model has a more focused light but has the fogs to see the sides of the road???
Old Dec 15, 2009 | 10:41 AM
niko3257's Avatar
ha lol
thanks for the pics. deff see it now.
Old Dec 15, 2009 | 11:51 AM
fitisbamf's Avatar
i dont se why honda would take the time to make different headlights?
Old Dec 15, 2009 | 09:29 PM
specboy's Avatar
headlights manufactured in different locations maybe? The H4 bulbs have the tip of the bulb "painted/blackened/coated/whatever" so there's no light going straight out of the bulb anyway.
See below
~SB
Old Dec 15, 2009 | 11:59 PM
niko3257's Avatar
Just making sure u understand that it's not different headlights.
The only difference is the bulb cover. This is a part all by itself
that comes off by a screw i believe.
carrier
Dec 29, 2023 09:28 PM
oman
Dec 21, 2017 10:10 PM
fujisawa
Sep 26, 2012 11:37 PM
FELIXY69
Jan 7, 2008 03:42 PM
doogiefish
Jan 24, 2007 11:58 PM
