New Console/armrest
Old Jan 15, 2010 | 01:14 PM
polokid69's Avatar
Originally Posted by fmcfad01
Additional $200? The armrest costs like $179 online doesn't it? It's like $200 shipped.
like $189 shipped, just bought one two weeks ago. It was less than $200. The cheapest I found the factory armrest was $167 plus shipping.
Old Jan 18, 2010 | 08:55 PM
xm8's Avatar
xm8
Where can you order the arm rest for less?
Will a 5" garmin gps 1490T fit in it?
Old Jan 20, 2010 | 04:39 PM
polokid69's Avatar
I tested and my TomTom GPS will fit in there. The cheapest I found was at CFL honda for $167 plus shipping
Old Mar 8, 2010 | 10:25 PM
shegetstodriveit's Avatar
can I install a driver side arm rest onto the passenger seat? It feels like there is a possible attachment point under the material.
Old Mar 8, 2010 | 11:54 PM
qbmurderer13's Avatar
Not unless you get the OEM armrest from japan. Just the shape of it and the way it mounts to the seat.
Old Mar 9, 2010 | 12:14 AM
555sexydrive's Avatar
Which model has an armrest here? I know mine didn't come with an armrest attached. If it did I missed it, but I also replaced my seats the day after I brought the car home.
Nevermind, the MT equipped models do not have an armrest. Just looked at the Fit's page on Honda. I knew I couldn't have missed such a thing.
Old Mar 13, 2010 | 11:43 AM
Bowkr's Avatar
Hmm... so I have all the tools but the 12mm socket (13mm is the closest I have)...
Not good with tools. What bolt needs the 12mm, and would a 13mm socket or 12mm combo wrench work instead?
****Edit: turns out it was the most important bolts (for the bracket under the e-brake mount). Fortunately, there was enough play to use a combination wrench.
Overall, the install was quite simple and the armrest feels great. Loosening the e-brake helps, and you will likely still need to hold down that bracket when starting the bolt... and you might lose a screw under the carpet in the process... But other than that it is quite simple. Thanks for all the tips (e.g. 3mm -> 1/8", 8mm -> 5/16", 20mm -> 3/4"). I will keep the idea of stuffing rags into crevices next time, to avoid pulling up the carpet :-P.
Old Mar 16, 2010 | 04:22 PM
eljuero's Avatar
Hehe...its on my wish list too. I agree it should be standard but then again Honda wouldnt get out more money
Old Mar 16, 2010 | 10:00 PM
halfmoonclip's Avatar
Love mine; looks great (the standard one is a real POS), and the install is a little fiddly, but the online instructions can give you an idea of what you'll face.
IIRC, there is a template for the small holes, and the larger ones require a metric bit, which I didn't have. Drilled the holes with an undersize paddle bit and then opened them a little with a Dremel and sanding drum. A dowel (or pencil) wrapped in sandpaper would do as well.
Moon
Old Mar 22, 2010 | 07:49 AM
bigcanoe's Avatar
I installed mine this weekend. It wasnt a hard job with the online video and PDF available. I do miss the rear cupholder, and I am not sure I like the vinyl material on the new armrest as much as the cloth on the old one.
Old Mar 22, 2010 | 09:55 AM
IIRC, vinyl it ain't.
Due respect, but the original was a fuzzy, furry mess. I'm not meaning to argue here; YMMV.
Moon
Old Mar 22, 2010 | 10:57 AM
  #32
bigcanoe's Avatar
Its leather? I will have to give it the sniff test
My car is only a few months old, so its not too hairy and fuzzy yet, but I get your point!
Old Mar 22, 2010 | 11:06 AM
  #33
Yep. No 'hyde de nauga' here.
Got the car in October '09, and the original armrest lasted 'till Christmas, when my bride got me the console/armrest, rub strips and the applique for the rear bumper. I installed all three in a couple hours and only recall swearing once. Some of my projects make the neighbors close their windows.
Moon
Old Mar 22, 2010 | 01:30 PM
  #34
I'm new to parts ordering... is there an easy way to find the part and order, without knowing Japanese?
Wonder how much shipping would be?
Old Mar 22, 2010 | 04:08 PM
  #35
eljuero's Avatar
Or you can check singapore forum (GE Club Forum • Index page), need to register first
Here is the print screen of a thread from Auan's poison shop
I think prices are in singapore dollars...just a suggestion and check if parts are suitable for left driving car too.
Old Mar 23, 2010 | 12:42 AM
  #36
Irish4199's Avatar
Do you really even use the armrest? I don't think I'd have much use for it anyway...
Old Mar 23, 2010 | 12:46 AM
  #37
RE: the OEM console/armrest, since I drive with two hands on the wheel, I don't use it much. Passengers like it.
Moon
Old Mar 23, 2010 | 08:27 AM
  #38
bigcanoe's Avatar
60 miles a day on a straight highway with no variation in speed, yep I use it.
Old Mar 23, 2010 | 09:45 AM
  #39
I can't remember what a tangent piece of highway looks like...
But I see your point.
Moon
Old Mar 23, 2010 | 07:32 PM
  #40
blassty's Avatar
I had the armrest installed about 2 weeks ago. Very nice indeed. I almost lost a bolt under the carpet. Be very careful.
