Outside Air Temperature gauge
Old Mar 2, 2010 | 06:08 PM
RexRacer's Avatar
Cool Outside Air Temperature gauge
Has anyone picked up a good aftermarket gauge that displays the air temp outside the car? And where did you mount it? (I have seen a few but all I have found come with clocks etc. I would just like an easy to read temperature gauge that looks good inside the Fit.)
Old Mar 2, 2010 | 07:38 PM
spreadhead's Avatar
Old Mar 2, 2010 | 07:42 PM
Perrenoud Fit's Avatar
Old Mar 2, 2010 | 07:44 PM
something like this? This is from Show Chrome and has 5+ functions, it's a cool gadget.
Old Mar 2, 2010 | 08:48 PM
RexRacer's Avatar
Thanks for the quick reply and the install photo.
Old Mar 2, 2010 | 08:54 PM
RexRacer's Avatar
Originally Posted by spreadhead
Very cool but a little out of my budget right now.
Old Mar 2, 2010 | 09:06 PM
specboy's Avatar
I picked up a Bell from K-Mart. it's silver & Black which matches the Fit's interior. $8, matches, and works great. took 5 min to install.
~SB
Old Mar 3, 2010 | 12:12 PM
RexRacer's Avatar
~SB
Nice idea, but I can't find that particular Bell thermometer.
Old Mar 3, 2010 | 12:22 PM
circa40's Avatar
How about $8 and a little fiberglass?
Old Mar 3, 2010 | 12:26 PM
nothing's Avatar
Cool. Details?
Old Mar 3, 2010 | 12:41 PM
circa40's Avatar
Originally Posted by nothing
Cool. Details?
the meter cost $8 on ebay and I had to mold it to that lower panel. The power supply for the meter is from the 12v socket and the temp probe goes to the windshield wiper area.
I hope that helps
Old Mar 3, 2010 | 01:23 PM
Circa40 has the best idea!!
Old Mar 3, 2010 | 02:51 PM
TunaDaMan's Avatar
You can go with a ScanGauge; while cruising the intake temp should read at the ambient air temp
Old Mar 3, 2010 | 04:46 PM
RexRacer's Avatar
Cool. Details?
This is perhaps the best. I'll try to find it on eBay.
Old Mar 3, 2010 | 05:31 PM
circa40's Avatar
This is the place I bought mine from.
eBay Seller: sureelectronics: temperature, Business Industrial items on eBay.com
They are pretty cheap and gets the job done
Old Mar 3, 2010 | 07:09 PM
specboy's Avatar
My local Kmart had it in the Automotive section.
Found it online as well at amazon : Amazon.com: Lighted In-out Thermometer and Clock: Automotive
I'm sure any autoparts store will have it too. I've seen it in Autozone, etc... before. The reason I like this is I can leave it on outdoor thermometer even though it has indoor as well.
Personally, I'm not liking the custom-fabbed thermometer because the red doesn't match the blue lighting in the rest of the car. Location for me isn't ideal either as I like everything in my field of view.
~SB
Old Mar 5, 2010 | 01:49 AM
SteveInNC's Avatar
I found the one that Perrenoud Fit shows in post #12 above at Ebay for Buy It Now US$1.59 with $5.99 flat-rate shipping. The seller has 99.4% positive feedback (16804 sales). I might just have to signup with Fleabay for this. It is apparently powered by button batteries and/or by a 12v lighter plug. The backlight is powered only by the plug. I'm hoping that this means that it is always lighted if powered that way. One of the problems I have with many of the auto units is that you have to push a button for the backlight. I particularly like that this one shows both outdoor and indoor temps at the same time.
Here's a link.
I'm not affiliated with the seller, etc. etc.
Edit: Here's a link (Becar Industrial) to the manufacturer's page for this clock/therm. It shows one sitting on a car dash, and gives dimensions (in mm) to give you a better idea of the scale.
Old Mar 5, 2010 | 07:35 AM
specboy's Avatar
Here's a link.
That's the one thing I wish my thermometer had... plug-in back-lighting. have to push the button to get the blue backlight to come on but with my positioning, it's too far away. I think I'm going to mount an LED right in front of it with a push button allowing me to kick it on when I want to see the thermometer.
I'm not really liking the becar above because it's a clock... with an indoor/outdoor thermometer added on. I passed over alot of the inexpensive ones because they all had the clock as the largest display item.
~SB
Old Mar 5, 2010 | 08:54 AM
annunC8's Avatar
I hope that helps
More questions! How/where did you route the wires to the windshield wiper area for the probe? A hole under the dash to the wiper area? The simple way, such as just passing it through a window?
Some people run temp/compass sensors through the firewall and up around or behind the bumper area. Since this isn't really a true auto sensor, just want to make it as neat and clean as possible. I hate wires all over the place!
Also, how did you wire the power supply to the 12v socket on your Fit. Does it come with a cable that just plugs in, or did you have to hardwire it? Slight details, maybe?
Thanks for any and all info.
Old Mar 5, 2010 | 10:37 PM
SteveInNC's Avatar
~SB
You might be able to find this one: Becar T24
It's only an in/out thermometer. Unfortunately, it seems to have a backlight button also. I suspect that some judicious soldering could wire that permanently on. If the 12V supply is connected to a switched source in the car, I bet that the light won't light unless the ignition is on, and since it's just a thermometer, there isn't any need for a constant power source to drive the clock. Electronic thermometers tend to have very rapid sensor times, so within a few seconds of turning the car on, it's probably an accurate reading.
