Lug Nuts Locks, what should I buy
Old Apr 22, 2010 | 01:36 PM
redlucy's Avatar
Question Lug Nuts Locks, what should I buy
Hello,
I know if they want to steal them they will, but I'm just adding little extra work for the thief, so I'm in the market for purchasing a set for my 2009, but I don't know which one will fit, MFR are no help I called Gorilla company, jc whitney they don't know, my question to you is, what thread size? shape? (I do believe this is Acorn shape) and brand/model name model you suggest I should install in my 2009 fit sport.
thanks in advance
Old Apr 22, 2010 | 01:54 PM
jondotcom's Avatar
Go to any americas tire. They have very nice locks for ~$19.99 or so(make sure they are the gorilla ones for HONDA).
They carry the premium ones, not like the ones that will turn into a ball of rust that kragens have.
I also need to go by and get some for mine! I just went through this 1 yr ago on my jeep (4 tires alone on that thing cost a grand, so I definitely needed locks!)
Old Apr 22, 2010 | 02:03 PM
bmxman's Avatar
You need 12x1.5 many manufacturers make them. I use Rays just because they're not as common and they're very light...the only downside is they don't come cheap.
EDIT: Koala is right! I just assumed you had aftermarket wheels. I never roll on stock wheels
Old Apr 22, 2010 | 02:06 PM
Koala Yummies's Avatar
Honda Lugnut thread diameter and pitch= M12 x 1.5mm
The OEM wheels us an Acorn/ball seat pattern, so you need a lug/lock that matches that. Honda makes OEM locks that will do the job just fine. There are a few other brands, but check to be sure they have the correct seat, or just buy the OEM ones with no worry.
Do not puchase aftermarket "tuner" lugnuts (Rays, Muteki, Skunk 2 etc) [edit, like the ones the guy just posted above my post] for use on the OEM wheels, they do not seat properly, will wear and can lead to the wheel coming off the car. The tuner lugnuts use a lug seat with a 45* taper, as opposed to a curved "acorn" shape of the OEM wheel's lug seats.
Old Apr 22, 2010 | 07:50 PM
teamkitty's Avatar
Old Apr 22, 2010 | 07:59 PM
jondotcom's Avatar
you can find them for $19.99 on amazon (honda gorilla locks)
Old Apr 22, 2010 | 08:18 PM
trancedsailor's Avatar
12x1.5? You can use the same locks I have on my Miata
Mazda Performance Parts: McGard Spline Drive Lugs and Tool Set
spline-drive lugs ftw. Not hex-drive. Chances are way less of a thief having a spline-drive wrench
Old Apr 22, 2010 | 08:29 PM
Vash's Avatar
thats a good recommendation, because the ones with the keys that is like a 2 peice mechanism will break really easily and the key would be useless, and the lug would be stuck, it happened to my car, and i had to take it to a wheel shop for them to weld the key to gether on a lugnut to take it off
and apparently the place that take it off for me said they do this all the time on those autozone/advance autoparts kind of wheel locks.
Old Apr 22, 2010 | 09:39 PM
t.bone's Avatar
i had some McGard's on my EK. loved em! prolly gonna get some for my new car.
Old Apr 22, 2010 | 10:57 PM
mike2100's Avatar
Go with OEM Honda. They match the weight of the locking nut to the regular nuts exactly, so you don't have to worry about balancing issues. They can be had for $35 plus shipping from College Hills Honda: Honda Fit Alloy Wheels - Genuine 2009-2010 Honda Fit Alloy Wheels
I'm sure you could get them cheaper from somewhere else on the net (CH charges a lot for shipping IMO).
Old Apr 22, 2010 | 11:35 PM
get_FIT's Avatar
i went muteki =] blue ones.
Old Apr 23, 2010 | 01:59 AM
j1nNju1c3's Avatar
Price range on ebay: $167-$200 +
YikeS!
Old Apr 23, 2010 | 02:23 AM
jondotcom's Avatar
But do they have the correct honda ball seat for oem wheels? Those rays lugs won't work correctly.
Old Apr 23, 2010 | 02:26 AM
jondotcom's Avatar
How do you know that? I can't find anything that says they are the same weight.
Old Apr 23, 2010 | 08:36 AM
mike2100's Avatar
It says it on the package. "Will not affect balance" or something to that effect. In order to not affect balance they have to weigh the same.
Old Apr 23, 2010 | 10:48 AM
jondotcom's Avatar
Thanks, that's interesting. I was under the impression that a slight difference in weight at the lug would have no perceivable impact to balance (the further outward you go the more impact).
Thus, I ordered these last night:
"Gorilla Automotive 38431N Honda Ball Seat Wheel Locks (12mm x 1.50" Thread Size)"
Automotive; $19.99
Sold by: Amazon.com, LLC
Old Apr 23, 2010 | 10:55 AM
crash001's Avatar
Get two different sets that look similar and then it's even more work
Old Apr 23, 2010 | 01:33 PM
If the OP or anyone for that matter is wanting these locks or lugs for OEM Honda wheels, be it alloys/aluminum or the steel wheels, if the wheels came from Honda, then those lugs/locks would NOT be a good recommendation.
Please read my post above, as the aftermarket 'tuner' style lugnuts do not have the correct lug seat-pattern for OEM factory Honda wheels, they are meant for aftermarket wheels with a 45* tapered lug seat. The OEM Honda wheels all use an "acorn" or "ball" shaped lug seat.
This happens all the time on these internet forums, people think they know what they are talking about/recommending and recommend the wrong thing. This is a very serious safety issue, and people have been pushing their luck all the time with tuner lugs on OEM Honda wheels. If you don't use the correct lugnuts and your wheels come off at freeway speeds you won't get much sympathy.
Lug nuts are one of the most important aspects on the car, do not screw it up, cheap out or do anything misinformed.
Omg even wikipedia knows. Lug nut - Wikipedia, the free encyclopedia
Honda uses a spherical rather than a tapered seat, but the nut performs the same function.
Old Apr 24, 2010 | 02:47 AM
j1nNju1c3's Avatar
So I have a question: I have a set of Volks, what kind of lugnuts shoud I use? I found some cheap Rays lugnuts on craigslist. Should I use that?? It is 12 x 1.5 and I think it's 60* tapered? Is that good or no?
Old Apr 24, 2010 | 09:50 AM
Gbaby2089's Avatar
If you actually have volks then yes use after market lug nuts
Although I've heard bad things about Ray's lugs
