Glued vinyl mat on the floor
Old Apr 25, 2010 | 01:10 PM
igor17's Avatar
I got 2010 Base Fit, then bought carpet OEM floor mats from CFL Honda, here is a question - driver side of my Fit has a vinyl square mat glued to the carpet. I can't remove it, it is glued really well. But the carpet floor mat has the spikes on the back which suppose to grab the carpet to prevent slipping.
I understand there hooks to install, but does everybody has this vinyl mat?
Do you just put OEM floor mat on top of it?
Thanks in advance, all answers are appreciated.
Old Apr 25, 2010 | 01:13 PM
neil patrick harris's Avatar
the mats won't slip at all when you have the clips in place. there is actually a slit near the rear of that glued mat to let you know where to install the clips for the driver's mat.
Old Apr 25, 2010 | 01:18 PM
igor17's Avatar
So everybody has that glued vinyl, not just me?
Old Apr 25, 2010 | 01:29 PM
jnesselroad's Avatar
right. it's there for people that don't have the mats. it's a heel guard so you don't wear a hole through your carpet.
yup.
just noticed you live on the peninsula. me too.
Old Apr 25, 2010 | 01:36 PM
igor17's Avatar
Everybody - thanks for prompt replies.
Old Apr 25, 2010 | 03:36 PM
know-nothin's Avatar
I didn't even check my Fit because it came with mats from the dealer but every car I've owned since the 1960s has had this in place. Like another member said, if you chose not install a mat (and I don't of anyone that does not install some sort of mat) this would prevent you wearing a hole through the carpet when you work the pedal.
BTW, use the clips when you do the install.
swebob
Nov 9, 2010 12:28 AM
surfer1955
Jun 29, 2010 08:49 AM
john-fit
Oct 7, 2009 08:29 PM
prufrock
Oct 13, 2008 06:58 PM
Jonniedee
May 18, 2006 09:49 PM
