2009 honda fit window vibration?
Old May 4, 2010 | 10:52 PM
canuck901's Avatar
anyone else have this issue, I have a vibration on the drivers door window on my fit, when I put my hand up againt the glass and pushout it goes away, its a bit annoying but not terrible
anyone else have this problem?
Old May 5, 2010 | 12:20 AM
JJIN's Avatar
i have this shake and rattle once in a while when i have the front windows opened just a crack. just even enough for the visors to match up with the edge contours of the windows.
Old May 5, 2010 | 12:23 AM
Dee K's Avatar
mine does this and so did a civic i used to own. It goes away if you open the window wider.
Old May 5, 2010 | 12:25 AM
crash001's Avatar
Dose it on mine as well
Old May 5, 2010 | 10:21 AM
einstein77's Avatar
Never noticed
I'll check my 09 out and let you know. I never noticed.
Old May 5, 2010 | 02:41 PM
eljuero's Avatar
My Jazz the same. Grrr....
I believe this is also the cause for anoying rattle noice from the door when driving over bumps on the road with closed window. I guess that the window hits the door seals then.
Old May 5, 2010 | 06:49 PM
canuck901's Avatar
there's gotta be a fix for it...lol, maybe a new weatherstrip or something....it sounds just like a loose rub or something, might have to take the door inside panel off and have a look
Old May 8, 2010 | 01:59 AM
blackvitzrs's Avatar
my car has it too, the window is too big and the window channel is not tight enough against the glass hence the glass will "move" if the window is opened less than 1/3 of the way.
its very annoying. honda should fix it for us.
Old May 8, 2010 | 02:39 AM
eljuero's Avatar
Not "should", "must"
Though my Honda dealer doesn't deny the problem he would like to wait for Honda recall
But its interesting that this problem is only with left front window
My car is one year old w/o any major problem but these little problems are very annoying as well (window vibration, rattle noice from the door, from the dashboard, trip computer inaccuracy) ... huh...I had better opinion of Honda quality because I didn't have this kind of problems with my 14 years old Daewoo Racer.
runbikerun
Apr 17, 2023 08:57 AM
Blackberry Goose
May 31, 2011 09:45 PM
RetroAttack
Oct 15, 2010 10:32 AM
PoLLyWoG
Feb 25, 2009 08:33 AM
spin out
Feb 19, 2009 10:39 AM
