So whats the purpose of the first gear (5MT)?
Old May 23, 2010 | 05:30 PM
wilcoholic's Avatar
I think you should give up your MT for an AT or better yet a bus pass. Sorry to be so blunt and a dick about it, but you said you are afraid you are hurting your car, well it sounds like you are hurting your car with your shifting techniques.
The motor is not going to be hurt if wrung out, in fact you will help the motor by ridding it of carbon deposits that build up when it is always short-shifted which is what you seem to be doing. Want to extend the life of the motor, stop being a girly girl and step on the go pedal a bit more.
No, I will never get an AT unless I have no choice. I am having too much fun driving MT and it's much cheaper/more effective. Well I adjusted my driving style to getting it smooth. If the car doesn't rattle, shake, lurch, make weird noises then I guess it's ok.
I really usually shift around 3k. Going as low as 2.5 and as high as 4k. I see no reason to shift higher because my cruising speed is usually not that fast (not slow either!). Or is it advised to shift at redline then taking the 2nd gear all the way up to my cruising speed and then shift to 5th while skipping 3rd and 4th?
You know I think the bus pass remark is really offensive. I know I am not the best driver in the world but you don't have to advise me to take the bus instead. And I am pretty sure that I can drive a manual transmission!
Old May 23, 2010 | 05:47 PM
Krimson_Cardnal's Avatar
wilco - There's no reason to push the RPM's other than for the fun of it.
To 'clear out carbon' you need to take it to the limit in 2nd then, simply lift your foot off the gas and let the engine back pressure slow you and, at the same time, blow out the carbon. Idea is to get those rings chiming and loosen things up.
HOWEVER, I have seen no indication on this forum that suggests the FIT vtech is prone to carbon build up. The above is recommended for a 5L NorthStar engine commonly found in the Cadillac. A performance engine way beyond the 1.5L vtech. Like 175 ponies beyond.
I doubt I would ever scream my little FIT like that, but it will take it.
I see nothing wrong what-so-ever with what you are doing.
K_C_
Old May 23, 2010 | 05:55 PM
einstein77's Avatar
Agree
Originally Posted by specboy
I've never had a 5MT car with a useful 1st gear worth downshifting into (with the exception of being in MAJOR contstruction where you just crawl.... then the Prelude was decent with it's 2.0L engine but it was for crawling, not downshifting to for performance reasons - or even engine braking)
1st gear is an acceleration gear [plain and simple] and is there to prevent regular lugging of the engine. Do a 0-60 with and without 1st gear. The time spent for the 1-2 shift is much shorter than the lugging the engine takes to get up to the 2-3 shift point. Also, try starting on a steep hill at a stoplight in 2nd gear.
The only time I don't use 1st gear is when starting in the snow, the rest of the time, the car just rockets off the line in 1st gear. ... 2nd; not so much.
~SB
I agree completely. It still accelerates faster using 1st.
Old May 23, 2010 | 06:49 PM
Goobers's Avatar
man, using an iPod touch on forums is hard, so I'll try to be quick about this.
You are shifting too low in terms of 1st gear.
I've been relucatant to respond to this thread because it's been a while since I drove stick. So you'll have decide how valid my comments are.
IGNORE the tach, don't look at the RPMs when you drive. In the case of the Fit, you'll also have ignore the engine noise if you can, just make sure you recognize the actual redline.
When I used to drive a Ford Escort, it didn't have a tach. So I learned to push each gear until I felt it was LOSING power, then shift. Trust me there's a point where it feels like the engine feels like it's free spinning. Once you figure out where that is, you then learn to shift a little before that.
After a while you'll get used to the engine noise an recognize when to shift.
Downshifting is a slightly different matter. If I have to gradually slow down, which was rare, I'd slowly lift my foot off the gas until I fell like it's about to stall or if the car no longer slows down (which ever first), then down shift. Again, after a while you'll feel where this is and can do it a little earlier.
In terms of plain braking, that's a bit of an issue for me. I don't do the whole engine brake to stop deal. I just pop it in neutral and brake. Whether from 25 or 65 mph to 0.
But since you appear to make use of it, rumbling in 2nd means you should be in 1st, high RPM or not.
Basically, you have to feel out the car.
Old May 23, 2010 | 10:04 PM
bmxman's Avatar
~SB
QFT (ten characters)
Old May 24, 2010 | 05:16 AM
Type 100's Avatar
Simply put, you need all the gearing you can get because the engine has a surfeit of neither power or torque. That's why first gear is so huge.
I putter along in crawling traffic in first gear, no problems.
Second gear is great for overtaking, but it's not a good ratio to start off from.
Old May 24, 2010 | 12:20 PM
nikita's Avatar
First gear is intended only for starting off from a dead stop. Yes, it is synchronized so you can downshift into first while moving, but why? Due to aggresive gearing, starting in second is possible without lugging the engine on level terrain with only one or two people on board, but not uphill with a full load.
"Standard" transmissions on American cars and trucks used to have a non-syncro first gear that was, unless you double clutched, only selectable from a dead stop. I once drove an SS396 Chevelle with the close ratio four speed and it was easier to start in second and skip shift directly to fourth to avoid chirping the tires.
Old May 25, 2010 | 07:38 AM
specboy's Avatar
Honda engines have historically had less torque than the competition due to the engine size. While many other companies are using 2.0L and 2.4L engines (or a Turbo'd 2.0), honda has typically been at 1.8 or 2.0 and producing higher HP. The FIT is a great example of this. 1.5L Producing 117hp VS the aveo 1.6 Producing 106 So was the integra GS-R & type R. 1.8L producing 170hp or 195hp. The current K20 in the Civic Si Produces 198hp while the QR25 in the Nissan SER Spec-V produces 200hp.
The down side is torque... and to effectively have a usable 1st gear for downshifting to, you need to have it geared higher... which requires a higher torque engine. (which most hondas do not have). so 1'st gear in a honda 4cyl will never be as usable in downshifting as it will be in other cars because it MUST be geared lower to compensate for the lack of torque (compared to the competition).. BUT... because of the honda engine being smaller, you have better efficiency and you still end up with more power than the competition. It's a change of driving style that needs to be adopted by people switching to a higher revving 4cyl. It's most often noticed by People coming from German or American Cars.
~SB
Old Jul 30, 2010 | 05:14 PM
THEproFIT's Avatar
Originally Posted by Koala Yummies
If you can't find em, grind em. :P
But I have no complaints about the M/T 1st gear. I've downshifted into it plenty of times, and gone into 1st from 2nd, even 3rd gear, for U-turns as well. From a dead stop I don't start from 2nd gear unless the person behind me has been acting like a fool, and I'm welcoming a honk.
It sounds to me like the OP is short-shifting (shifting early), or just being a little conservative on the RPMs. Not like that's a bad thing. But you can take it up, Honda's are well known for being 'rev happy'.
if you find too many fools behind you it's because YOU R THE FOOL
if you keep right EXCEPT TO PASS you may find that all the fool magically disappear!!
Old Jul 30, 2010 | 05:18 PM
THEproFIT's Avatar
it was merely easier for you
you defeated the whole purpose of the close ratio gearbox (performance, not ease of use)
Old Jul 30, 2010 | 09:27 PM
Sherpa's Avatar
I gotta say I agree.. no idea on the carbon build up thing.. but these cars are made to rev.. even the old pre v-tec d15 powered cars needed to have the piss reved out of them to move.
The earliest I shift is 4k unless I've hit cruising speed...
Stoli124
Aug 1, 2023 06:33 AM
m_x
72
Nov 16, 2018 04:10 PM
Lyon[Nightroad]
Jan 16, 2012 07:24 AM
tonyd3773
Jun 21, 2008 02:51 PM
tonyd3773
Jun 20, 2008 04:33 PM
