different size wheels
Old May 25, 2010 | 11:57 PM
snowboardpunk's Avatar
so i was wondering my front tires have alot of camber wear and i was gonna get some used tires until my rear ones are worn down too since they are at like 50% tread. but my friend says he has some 195/55/16's for me and the stock rims are 185/55/16's. so i was wondering will it make that much of a difference if i put the 195's in the rear and 185's in the front?
Old May 26, 2010 | 01:22 AM
555sexydrive's Avatar
Camber wear, is your car lowered significantly from stock? If not, then what you should be doing is going to get an alignment done to get it within spec.
If it was me, I would put the 195s up front versus in the rear, afterall it is a FF configuration car and the extra meat up front will induce a little bit more rear end movement (if pushed). The other way will induce understeer which is something one shouldn't be looking for.
Old May 26, 2010 | 03:39 AM
hmm alrite maybe ill switch them up front and yea i got an alignment already =-)
n9cv
Apr 26, 2015 05:38 PM
linnboi
Apr 24, 2012 10:25 PM
piperpiperpiper
May 10, 2010 07:50 AM
coupdetat
Feb 20, 2008 07:57 PM
Si Sancho
Jan 27, 2008 07:28 PM
