Torque Converter does not lockup in 5th gear on S mode?
Old Jun 25, 2010 | 03:32 AM
Lyon[Nightroad]'s Avatar
FYI
Lock-up Mechanism
The lock-up mechanism operates in all five gears in D, in 3rd gear in D3, and in 3rd and 4th gears in S. The pressurized fluid is drained from the back of the torque converter through a fluid passage, causing the torque converter clutch piston to be held against the torque converter cover. As this takes place, the mainshaft rotates at the same speed as the engine crankshaft. Together with hydraulic control, the PCM optimizes the timing and volume of the lock-up mechanism. While shift solenoid valve D is turned on and off by the PCM, shift solenoid valve D pressure switches the lock-up shift valve lock-up on and off. A/T clutch pressure control solenoid valve A and the lock-up control valve control the volume of the lock-up conditions.
Old Jun 25, 2010 | 04:00 AM
Occam's Avatar
uh... mine does. I can shift to M5 and visually see the rpm's jump when it unlocks.
Also, what is D3? I have P R N D S.
Old Jun 25, 2010 | 04:43 AM
Maybe it does not apply in manual shift mode :/ d3 is base model
Sigma Projects
Oct 26, 2019 10:34 PM
nittany
Nov 19, 2014 07:12 PM
over40pirate
Aug 29, 2013 04:28 AM
growl92
Jun 6, 2011 02:04 AM
iss407
Aug 7, 2009 11:46 AM
