17" Wheel Fitment - I've searched
Old Jun 28, 2010 | 06:26 PM
sgtiger's Avatar
I just purchased my 2010 Fit, and I have a set of nice 17" wheels and tires leftover from my old car.
The wheels are Kosei K1-TS's.
Offset: 42mm
Backspacing: 5.65"
Bolt Pattern: 4-100
Weight: 15.0lbs.
Finish: Light Grey Painted
Construction: 1pc. Low Pressure Cast
Finish Warranty: 1 Year
The tires are 215/45's.
(link: Kosei K1 TS Light Grey Painted )
The car will never be lowered. The closest thing I've found on this board is EK3_Ferio who stated he/she ran:
Wheel: Rays 57 Motorsport G07WT
Offset: +43mm
Color: Winning Blue
Tire: Nitto Neogen
Lowered?: Yes
If Yes, What Setup?: Espelir Active Super Down
lugs: Projecy Kics Caliber 24 Heptagon
Front Rubbing: None
Rear Rubbing: None
Will mine rub? Opinions? Camber issues? I just want a good set of wheels for the summer and use the stock wheels as snow rims.
Old Jun 28, 2010 | 08:54 PM
skinny's Avatar
no they will not rub
Old Jun 29, 2010 | 08:24 AM
BakedCookies's Avatar
They will not rub, you will not have any camber issues if you are not modifying the suspension.
With that said, IMO, they will look like poop if you dont lower it.
Old Jun 29, 2010 | 10:22 AM
sgtiger's Avatar
Thanks for the responses!
I am hoping they don't look too bad with the higher profile tire.
bradpeterson2
Apr 3, 2012 01:43 AM
annunC8
Oct 14, 2010 11:46 AM
peenutz_fit
Jan 18, 2009 05:28 PM
Korywithak
Nov 25, 2008 12:58 AM
kurtdesch
Apr 27, 2006 10:08 AM
