fixing the damn foglamps, the poorman's way
Old Jul 10, 2010 | 11:07 AM
Red 05's Avatar
I thought I would share my poor man's way of fixing a foglamp lense.
So after sattering one and cracking the other, I had enough and set about mending it. I pulled the fog lamp apart and found that it comes apart into 2 main parts. I figured a sheet of lexan sandwiched in their would accomplish what I was looking to do which was make it look not broken.
Seeing as I work at a Hobby Lobby in town, I did some shopping after work and found a sheet of lexan for 99 cents, but ended only paying 50 cents for after a discount. Five minutes with a pair of scissors and two test fits later it's in. It's perfect. I'm pretty sure if I used the fog lamps I would melt the plastic, but because the lexan cost me less than a dollar and there's plenty left over, I'm going to try them tonight for about 15 minutes and see what happenes. I'm not going to be able to post a reply until probably next Saturday but I'll get back in touch.
Old Jul 10, 2010 | 01:16 PM
yah, thick lexan (4mm+) should work just fine...and it wont's shatter next time.
Old Jul 10, 2010 | 01:43 PM
reako's Avatar
I remember reading someone else trying this with lexan recently as well. It worked ok for a bit but then they saw discoloration and other issues with the lexan. So just keep a close eye on it. Good luck to you though!
Old Jul 10, 2010 | 01:44 PM
Btrthnezr3's Avatar
Good job! Way to be a DIYer.
Sooozun
Jan 31, 2013 10:36 PM
Red 05
Dec 8, 2011 04:45 PM
vwli
May 24, 2009 10:28 PM
Tounge73
Jan 31, 2009 11:39 PM
jj racing
Sep 10, 2008 10:09 PM
