DIY: Floor mat clips for passenger side floor mat
Old Jul 10, 2010 | 05:24 PM
Raouf's Avatar
-Like myself, I'm sure you all are tired of the passenger side floor mat always sliding up. This is a way I fixed that problem.
Disclaimer:
The following is provided as a GUIDE ONLY, and neither myself, nor FITFREAK.NET endorse, recommend, encourage nor take any responsibility for the outcome of someone else doing the following. Do at your own risk!!
Tools needed:
-box cutter
-13mm pipe
-blow torch
yes that's all lol
Parts needed:
-Floor mat anchors, if you order from the site I used, I would suggest buying something else as well because shipping was crazy high for just 2 little clips, but my buddy wanted an Accord horn for Si so we split the shipping. This is the cheapest site I found for them.
Honda Automotive Parts
-The part that the clip twists into (sorry I have no clue what they are called ) But I resurrected them from my old carpet mats from my old fit. For easiness I'm gonna refer to them as the 'plastic circle'...hehe
alright!
here's where that pipe comes to play (no pics, hands were full, sorry!)
take the pipe and heat the end up with a blow torch! The thing about doing it this way it is one clean cut and the melted plastic seals the hole. but you have one chance at doing it. You could use scissors if you wanted but I wouldn't recommend doing it that way
also pluck off the little rubber poky things off around it so the backing sits flush
repeat for the left side
then simply slide the 'plastic circles' in and clip the backing on
TIP: put the backing on the opposite way, I found that it is more secure this way
next you will need to take the clips and install them in the carpet like you would the drivers side.
http://www.collegehillshonda.com/ins...seasonmats.pdf
throw the mat on and twist clips to secure (duh lol)
after that you're done!
Old Jul 10, 2010 | 09:21 PM
BakedCookies's Avatar
that is awesome! Just need to gather the parts.
Old Jul 10, 2010 | 09:51 PM
Krimson_Cardnal's Avatar
Yeah - like those plastic washer thingies.??? Some kind of grommet might work. It's the keyhole slot to take the anchor though.
Old Jul 10, 2010 | 10:16 PM
jagass's Avatar
This is a very nice idea man. I will try to work it out.
Old Dec 21, 2013 | 11:40 AM
connor55's Avatar
Is there a part number for those rings? Want to pick up the parts tomorrow if I can.
Old Dec 21, 2013 | 11:58 AM
imagematsau's Avatar
You can always have custom made car mats-- custom design,size and all.
Old Dec 21, 2013 | 12:12 PM
connor55's Avatar
If I could go back, that's what I would have done. Now I'm stuck with the oem mats and just want to keep them from slipping around.
Runner140
Aug 30, 2012 10:03 AM
codenamezero
Jan 25, 2012 08:14 PM
Ultrawolf
Feb 16, 2011 04:59 PM
surfer1955
Jun 29, 2010 08:49 AM
igor17
Apr 25, 2010 03:36 PM
