Engine out the top?
Old Jul 26, 2022 | 06:27 PM
mojonixon's Avatar
Engine Out Thru Top, with Photos...
Hi all, yes the engine can be removed thru the top pretty easily, as long as the alternator and the first catalytic converter are removed. That converter can then be stowed above the steering rack to keep it out of the way... see pix. Engine removal thru the top means no need to remove the subframe or steering rack.
Hope this helps somebody!
Old Apr 23, 2023 | 06:38 PM
BukaZ's Avatar
Thank you for this info and thanks to everyone that chimed in. I do not have access to a lift, so I was hoping a crane would suffice. My question - what's the maximum tolerable weight support of that crane in your image?
Old Apr 23, 2023 | 10:33 PM
mykizism's Avatar
The weight limits are stated on the adjustable length points on the engine crane itself. (Review Picture) above
2 - Ton
1-1/2 Ton
1 Ton
1/2 Ton
1 Ton = 2,000 LBs (Pounds)
Old Apr 24, 2023 | 08:19 AM
BukaZ's Avatar
2 - Ton
1-1/2 Ton
1 Ton
1/2 Ton
I didn't notice that on the image. Thanks for this info.
jazzivtec
Nov 9, 2014 03:53 PM
Edwood
Dec 21, 2010 03:54 PM
Midnightfit
13
Apr 21, 2008 09:46 PM
Injundon
Oct 9, 2007 02:26 AM
NMG
Jul 4, 2007 01:28 AM
