Just Got One!!!!...I have questions
Old Sep 6, 2010 | 11:01 PM
gschram92's Avatar
Hey guys, Just got a 2010 Fit sport, Blue Sensation. Over time I would like to ( more or less) trick it out. New rims, Tint windows, interior, engine(performance) and exterior. I would like to know what order I should prioritize things and or what else should I do and what I shouldn't. Also o the rims, what a ood size of rim and tire, i wuld like bigger thean stock but dont want to raise the car at all if I can....Thanks alot.
Old Sep 6, 2010 | 11:24 PM
Java^FiT's Avatar
I am also a new owner of a 2010 BSP and I will tell you what i have done just in the first month.
First off I would say definitely get tints done like ASAP. it makes it look so much better. I have 35%'s and i am very content plus im likely not to get ticketed with 35's rather than if i had 20's but check ur local laws.
Def get some aftermarkets. Personally im not a follower so TE37's were def not on my list of rims so i went unique and got all white 17's with 205/40/17's
If your planning on lowering this is the size to go with, not 45 because there are alot of people that lower with 45's and rubbbbbbb.
for rims i used wheelfire.com. great deals and free everything.
Tints i went to a local place called Precision Tints 631-462-tint in commack, ny (lol thats my plug for the dude, really great guy and did an awesome job)
Good luck on everything! and congrats
Old Sep 7, 2010 | 12:37 AM
gschram92's Avatar
Just to show how noobie I am at this, what does each number stand for on the tire size? for example the one you mentioned. Thanks alot
Old Sep 7, 2010 | 12:49 AM
Oli's Avatar
Oli
205/40/17
205 tread width in mm's
40 aspect ratio of sidewall height to tread width, as in 40%
17 wheel diameter in inches
Old Sep 7, 2010 | 01:45 AM
Goobers's Avatar
Originally Posted by Oli
205/40/17
205 tread width in mm's (actually, its "section width," tread width is slightly different, link & link)
To add to that...
[(205 mm x 40%) x2 ] + 17 inches = calculated overall diameter (actual will vary slightly)
Obviously, you'll have to convert either the 205 or 17 to the other's measurement type.
Just FYI: Sport (USDM) is 185/55/16 gives just about 24" in diameter (slightly more, actually... 24.011811" etc or 609.9 mm).
So a 205/40/17 is going to be smaller (little less than 23.5"). It will throw your speedo and odo off ever so slightly. 205/45/17 is slightly more than 24.25". 215/40/17 is 23.77"***. A 195/45/17 comes pretty close (23.94"). A 225/40/17 comes closer at 24.087" but is pretty wide... not sure if you can get away with using a 225 mm wide tire (*** or even the 215 mm).
If you choose to stick with the 16" rim, you can go with 205/50/16 and get a slightly better match (24.07").
Old Sep 7, 2010 | 02:09 AM
johnkimble's Avatar
1) tint 2) lower it!
just got mine and that's what I'm doin!
Old Sep 7, 2010 | 05:58 AM
Type 100's Avatar
Forget power mods, not too many for the GE Fit I'm afraid.
Better wheels, tires and suspension ought to do the trick already. Tint will also help a lot on hot days. Good luck!
Old Sep 7, 2010 | 11:17 AM
Subie's Avatar
Go to Tire Rack or Edmund's website. They have good info on tire sizes and upgrade considerations. Also keep in mind tire weight and/or rim weight when upgrading. Lighter is better or at least same as OEM. Heavier defeats the purpose of upgrading. It will only load your engine even more unless you're just going for looks.
Old Sep 7, 2010 | 03:32 PM
gschram92's Avatar
Alright cool. thanks for the tips guys!
Old Sep 9, 2010 | 10:37 AM
susanlynn7's Avatar
I've yet to get windows tinted.
Old Sep 9, 2010 | 01:22 PM
DeeezNuuuts83's Avatar
Seeing how you're in San Diego, be aware of the fact that you can still get ticketed for tinting your front side windows, so be prepared to deal with that possibility. It's up to you, but personally, I don't think blue is one of those colors that looks significantly better with tinted windows (which is the case for a white or grey car), so you can still be fine with regular windows.
Aerya
Oct 16, 2011 04:55 PM
charmedimsure
Apr 14, 2011 01:32 PM
marcelosmack
Dec 30, 2010 12:07 AM
Java^FiT
Jul 15, 2010 01:11 AM
