3YO Nokian Hakkapalitas on Steelies for $300 Delivered. Good Deal?
Old Oct 4, 2010 | 08:54 PM
specboy's Avatar
ok... so a guy in the area has Nokian Hakkapalitas that he'll deliver mounted and balanced on 15" steel wheels for $300. He says there's about 75% of the tread there as they've only been on for 3 winters. They came from an 03 civic and will give me a minute lift (they are 185/65/15) which I wouldn't mind here in VT.
My Question. are 3 yr old Snow tires mounted on Steel rims worth it?
~SB
Old Oct 4, 2010 | 08:58 PM
M4psycho's Avatar
you should check to see what numbers are left on them. I believe all the Hakkas are marked with the numbers "8 6 4" right on the tread, to tell you how much tread is left. There should be at least the number 4 on it, and if the 6 is still on them then that's a pretty damn good deal. If it's just the 4 left on them then try offering $250...they'll probably be good for the 1 season and then you should consider new tires. Refer to the Nokian website for more info on their tire tread life markings!
Mooser1454
Oct 8, 2018 05:21 PM
stephenmarklay
Sep 19, 2018 02:26 PM
JA13
Apr 26, 2018 10:56 PM
Lymer
Nov 3, 2016 09:14 AM
davela72
Jan 4, 2008 01:04 AM
