TOE-OFF... help
Old Jun 1, 2011 | 05:24 PM
drumsauce's Avatar
Originally Posted by sr.sedan
well i have a question do the shims from the gd fit on the ge
The GD ones Do NOT fit on the GE. The GE hub assembly is welded to the axle. The GD hub assembly can be unbolted.
Old Jun 3, 2011 | 08:37 PM
DoYouFit?'s Avatar
I recently lowered my car and just did an alignment today, referring back to this thread it looks like it is by design...My rear left toe is .21, .07 from specified range. My tech said that .07 degrees is not significant enough to cause wear issues. My two cents.
Old Jun 3, 2011 | 09:10 PM
rhyneba's Avatar
Having moved from my Honda dealer to an Audi/Volkswagen dealership, I can be a bit more frank about some of these issues. IIRC, all alignment reports on Gen2 Fits show toe in on the left rear, close or slightly toed out on the right rear. I like the idea of shifting the rear axle. The geometry would be interesting to look at by loosening the bolts or mounts fastening the rear twist beam and torque it back down after a bit of prying back on the left and tightening whilst prying, forward on the right etc.... The issue with Civics with rear tire wear are from a slight dimensional problem with the rear subframe/
I traded my Fit when I took the position at Audi/VW or I'd tell you what it did tomorrow
"Flagrant Sentimentality warning"
The VW and Audi forum participants suck compared to you Fitsters. Mean, nasty, know it-all-bitches nearly to a man/woman lol.... I still read Fitfreaks every day and am trying to get back into being involved. New place has been crazy and my internet involvement has been napping in and out of Hulu The veedub forum members should be required to read Fitfreak before posting.
Still have my Oddyseys and my old Accords, though, so I still am with you guys.
b
Old Jun 3, 2011 | 11:36 PM
sr.sedan's Avatar
thanks for the head up, i was about to buy the shims for my ge
Old Jun 8, 2011 | 11:04 PM
dels's Avatar
As a follow up, I went to have another shop look at the alignment on my car.
Apparently, the issue with the rear left has worked itself out, or the initial reading (very similar to the OP's) was just an operator/mechanical error.
I suppose a second opinion helps.
bdcheung
14
Jan 5, 2020 08:47 PM
adock22096
Jan 12, 2018 08:25 PM
TeaNSimbaTee
Aug 15, 2011 09:12 PM
xxmostwantedxxx
Sep 3, 2008 09:32 PM
Si Sancho
Jan 27, 2008 07:28 PM
