Brake pads and Tires need replacing at 43k?
Old Nov 21, 2010 | 12:01 AM
wskwong's Avatar
Hi all,
My '09 fit brake pads are gone and the tires are down to the thread mark by 43000k. Is that normal for you guys?
What brake pad and tires would you suggest? just want normal durable, all-season ones....nothing really high performance.
Cheers,
Old Nov 21, 2010 | 12:42 AM
spoonek4's Avatar
U live in BC, Canada? If so that's 43000km then? Automatic or manual transmission?
Need to replace brake pads is quite normal for manual, even more reasonable if u got automatic. Tires, depends if u do tire rotation, check tire pressure regulary & perform alignment check annually. But doesn't sound too bad with 43000km.
Old Nov 21, 2010 | 01:06 AM
fitisbamf's Avatar
thats just about when i changed mine
Old Nov 21, 2010 | 11:00 AM
Ray731's Avatar
The tires on new cars are not the same quality as what you'd buy @ a tire store new. They last on average 30k miles. Sounds like you got good mileage out of them. I wouldn't know. I put new wheels and tires on the day I bought my Fit! Wish I would have gone 18" instead of 17". Brakes depend on the driving style and that mileage could be considered normal...
Old Nov 21, 2010 | 08:26 PM
wskwong's Avatar
cool thanks alot guys. I just check my old Civic record and indeed I needed to change its brake pad at around 35k, but the original tires on the civic last over 70k.
For you Canadian folks out there, where would you get your brake pads replaced? I've heard the original equipment usually doesn't last as long.
Old Nov 22, 2010 | 10:05 AM
mynameisphunk's Avatar
My original brake pads were still at 80% when I had my car's annual inspection at 38k miles. Completely depends on driving style and environment.
Old Nov 22, 2010 | 03:40 PM
Originally Posted by wskwong
Hi all,
Cheers,
dang... that's a lot of miles you got from the pads and tires.
check www.tirerack.com for your pads and tires. x294 talk to Alex.
Old Nov 22, 2010 | 05:19 PM
mdr40z's Avatar
How true, I have over 200,000 miles on the original pads on my hybrid.
Obviously, all highway travel
Old Nov 22, 2010 | 07:33 PM
mahout's Avatar
Hi all,
Cheers,
not out of line but based on your brake wear I'd suggest Hawk HPS for longer wear. andyou choose your tires by TireRack ratings for what you want.
Old Nov 22, 2010 | 08:07 PM
doctordoom's Avatar
Supervillain
Hi all,
Cheers,
you should just get replacement brake pads from honda since you're looking for longevity, not performance. OEM brake pads are cheaper too. http://www.bernardiparts.com/Honda-F...EPADS-FIT.aspx
only get hawk hps if you want to sacrifice some longevity in order to gain better braking power.
Old Nov 22, 2010 | 10:03 PM
p nut's Avatar
I actually would get the pads from Autozone. It's very surprising, but they will give you a set of new pads when the old ones wear out. I asked three different store managers and they all said the same. Get the Duralast Cereamic pads. They should be about $40 or less.
Old Nov 23, 2010 | 07:46 AM
mahout's Avatar
you should just get replacement brake pads from honda since you're looking for longevity, not performance. OEM brake pads are cheaper too. Honda Front Brake Pads (Fit) - Bernardi Honda Parts and Accessories
We've installed hundreds of sets of Honda disc pads and hundreds of Hawk HPS and the Hawks outlast stock pads 2:1. Stop quicker as well. And yes, the manufacuring cost of Hawks are greater than Honda stock for a good reason why few Honda dealers offer them.
Old Nov 23, 2010 | 01:27 PM
wskwong's Avatar
Thanks for all your input!! really appreciated.
Now i just remember I got a set of 15" 65R185 tires from my dad's corolla. Can I put them on (I know I will need new rims, but I think Canadian Tire offers generic 15" rims that fit anything). The stock 15" is 175 in width, so the only difference from the stock tire is the width.
Old Nov 23, 2010 | 01:43 PM
mahout's Avatar
185/65/15 tires are about a half-inch taller than stock GE so they'll work UNLESS the offset on the steelies are less than 45 mm, at least for a short distance not loaded.
Old Nov 23, 2010 | 04:28 PM
i run 185/65/15 snow tires on my GE with no issue. i can't remember the offset of the borbet wheels (ET38 or 40) but they were 15x6 or something. plenty of clearance.
Old Nov 23, 2010 | 04:41 PM
wskwong's Avatar
Nice....so I don't even need to buy rims at all then? Just put the 185/65R15" onto my current 15" alloys?
If like the previous post said it's half an inch taller than OEM, will that affect the odometer?
Old Nov 23, 2010 | 06:55 PM
Uncle Gary's Avatar
It will have an effect on the odometer/speedometer, but it will be negligable. Remember your tires change diameter by more than that over their lifespan, as they wear.
Old Nov 23, 2010 | 07:22 PM
JDMxGE8's Avatar
I changed out my front OEM brake pads and rotors at 30K. The pads wore out quickly because I tend to brake pretty hard, especially when entering corners at a high rate of speed. I went with Hawk HPS pads and DBA 4000 Series rotors. They're awesome! I changed out my tires at 50K for the new Bridgestone Potenza G019 Grid. They're awesome replacements for the OEM Turanza EL470. Not only do they a higher treadwear rating (460), but they also have more grip. I feel more comfortable in corners than I did with the EL470. The best part about the Grids is that they're cheaper than the EL470.
Old Nov 23, 2010 | 07:40 PM
bmxman's Avatar
lol @ you guys suggesting tire rack, Autozone, or any other places in the states... remember he's in CANADA. No autozones up here and getting something shipped isn't cheap when you have border crossing fees.
Old Nov 23, 2010 | 09:16 PM
wskwong's Avatar
No it's alright man.....lots of Canadians cross the border to pick up their tires and change down in the States
I am still not too sure about using the Corolla tires....When I go to Canadian tire and pretend to ask for generic steel rims, the 175/15" use a rim with a part number different from the 185/15".
But when I go to Kaltire, they said it's abosoultey fine because they claim manufacturer allows up to an inch difference......it will only be slightly taller.
If the Fit comes with 16" I don't see why it won't fit with a slightly bigger 15" tire. The only thing that I am worrying about is if the tire will pop off the wheel or something at highway speed, since it is a little wider than the original.
