wheel scrubbing
Old Nov 27, 2010 | 06:07 AM
ej20i's Avatar
wheel scrubbing
hey guys just got Buddy Club P1 Racing 16" SF
and im pretty sure that its a 42 offset with 50 profile and its scrubbing on the left only when taking corner or bumps.
should i reduce th profile to a 45 profile??but why on left only?
its rhd honda jazz btw
Old Nov 27, 2010 | 07:59 AM
Virtual's Avatar
Oh rubbing. I thought you wanted to scrub them clean lol.
Old Nov 27, 2010 | 08:53 AM
specboy's Avatar
What's the tire width? looks like you have a ____/50/16 tire. It could be that you are running too wide of a tire for that low of an offset. Assuming your current setup accurately reflects the same outer diameter as the OEM wheels, dropping to a 45 ratio would shrink you're overall diameter and throw off your speedo, shorten your warranty period (your car would think it's driven 100,000km when it's actually only driven 96,000km due to the wheel rotating 4% more than stock - numbers are for example only).
As for the rubbing on one side... is it rubbing on the inside, or outside? The outside (body) should be symmetrical but the inside by the engine bay is likely not symmetrical so if it's rubbing on the inside, it is likely due to the fact that the engine bay isn't likely symmetrical.
~SB
Old Nov 27, 2010 | 09:17 AM
mahout's Avatar
Very few cars are perfectly made so that there are small differences in the chassius and body positions and thats why you get rubbing on one side and not the other. Because you have a 6.5" rim width I expect you're running 205/50x16 tires. With the 42 mm offset and the 6.5" rim width the outer edge of the 205's are rubbing. I'm surprized both sides aren't. You must have a really cocked chassis. My suggestion is go to 195/50x16 if available and if not 185/55x16 tires. If you must stay with 205's go to 205/4516 tires
Old Nov 27, 2010 | 05:01 PM
ej20i's Avatar
its a 16x7 since buddy club only makes 16x7 P1s so yeah im running 205/50/16
should i go down to a 195/45?or would that stretched it too far?
Old Nov 27, 2010 | 05:17 PM
ThEvil0nE's Avatar
use this tool http://www.1010tires.com/TireSizeCalculator.asp
the +42 offset on fronts suggests you will have rubbing issues. are you on coilovers or lowering springs?
Old Dec 1, 2010 | 03:24 AM
ej20i's Avatar
Tein s tech. So 45 profile should be good?
FITProject
May 10, 2011 07:02 PM
Socialvegetable
Sep 29, 2010 02:41 PM
sedanimal
Feb 1, 2010 11:29 AM
Skytraveler
Jan 31, 2009 04:08 PM
korky
Apr 22, 2008 05:24 PM
