AEM F/IC and rsx-s Injectors Installed
Old Dec 17, 2010 | 01:34 AM
Lyon[Nightroad]'s Avatar
Figured I throw up pics from installing everything today.
Wiring was tedious but bearable. About 20-25 cut and soldered conections. ECM pin diagram was essential, only had to splice 2 of the 3 harnesses.
Thank goodness for heatshrink tape or this would have taken significantly longer trying to work in such a small area and using a tube on each one. Would I do it again, heck yes, not a chance I would pay $225 for a Boomslang harness. Also, don't forget to wire up your map sensor to analog a so you can clamp it later.
only used about half the wires.
Intake manifold and fuel rail has to come out to change injectors.
It's not until you remove the lower manifold that you realize just how insanely long the runners are. Great for low to mid power but no so much up top.
$100 shipped for 4 used rsx-s injectors. Would have gotten rdx injectors if I hadn't gotten a deal on these.
you'll notice the fit on the right is a bit different from the projected rsx-s injectors. Not sure if this is for the good, bad, or neither but they are a direct plug and play fit.
Got everything back together, tidied up the wires, spliced the vacuum line, and mount the fic to the ecm cover.
The cool thing is that you can just slide the cover off the ecm to remove the fic from the bay.
Stuck on some cheap weatherstripping foam to help block out the elements since the f/ic is not waterproof.
All in all, for someone who has never installed or tuned a piggyback before, this has been stupid easy. The software is great and even makes a base map for you. Only a few more weeks till boost
Old Dec 17, 2010 | 01:56 AM
ThEvil0nE's Avatar
+reps and subscribed
Old Dec 17, 2010 | 02:01 AM
j1nNju1c3's Avatar
subscribed. i wish i had the knowledge and time to do all this..
Old Dec 17, 2010 | 03:19 AM
DSC's Avatar
DSC
How much bigger are the RSX injectors? Any difference in driving with the F/IC?
Old Dec 17, 2010 | 04:09 AM
Ahh damnit. I knew things were going too good. The USB side of this thing seems to have bricked on me. None of my laptops are even detecting it when I plug it in. Now I have to wake up early and call aem before work to see if they will replace it. There's probably only 1 machine in the whole country that can hard flash it.
At least the injector tune is stuck in there in the meantime.
Old Dec 17, 2010 | 04:18 AM
kelsodeez's Avatar
UNBANABLE
thats an odd place to mount the fic. i would have mounted it under the dash but that is just me. protect it from the elements a little better
Old Dec 17, 2010 | 04:28 AM
Isn't the ecu in the cabin in the gd? That thing it's mounted to is the ge ecu. I'd have to solder in 25 extension wires and put them through the firewall.
Old Dec 17, 2010 | 06:03 AM
kelsodeez's Avatar
UNBANABLE
Man the more I heart about how the GE is built, the more I face palm.
Old Dec 17, 2010 | 09:24 AM
dewthedew's Avatar
i would never put an fic under the hood lol
Old Dec 17, 2010 | 04:09 PM
doctordoom's Avatar
Supervillain
+1 for f/ic going in the cabin
Old Dec 17, 2010 | 04:36 PM
I'll have to check and see if they make an extension harness long enough to get it through the firewall. Splicing wires is getting boring quick. You GD guys (with the ecu already in the cabin) saying you wouldn't put it under the hood would be somewhat like me saying to you that I wouldn't run boost without forged rods (since the ge already has them), though not quite so extreme.
Old Dec 17, 2010 | 07:21 PM
555sexydrive's Avatar
The newer Civics also have their ECU under the bonnet and not in cabin. It's not really an issue about being under there, but you may want to use your creative side and cover it up more.
GOOD SHYTE!!!
Old Dec 18, 2010 | 03:54 AM
These are my final 0-60 times for NA tuned with the new injectors.
10.2
10.2
9.9
My best ever, not bad for an at.
-custom sri
-colder spark plugs
-weaponr header
-egr delete
- fic +4% fuel over stock (-36% on 310cc Rsx injectors)
- ecu fuel trims dialed in to +6%
Btw aem techsupport is great. We managed to get it back up and running again.
Old Dec 19, 2010 | 05:15 AM
xm8's Avatar
xm8
Have you dynoed your car? If so, please post results?
Any plans for FI? If so, turbo or SC?
Old Dec 19, 2010 | 08:24 PM
No plans to dyno, maybe later after fi. I am already 80% done with the turbo. I just need to wait for the oil line kit to arrive and to get my downpipe welded on to the rest of my exhaust.
Old Dec 23, 2010 | 05:19 AM
xm8's Avatar
xm8
Where can you buy a harness for the AEM F/IC?
Do you have a link to the harness?
Old Dec 23, 2010 | 02:15 PM
The fic comes with a harness much the same way a car radio comes with a harness.
Old Dec 24, 2010 | 03:50 PM
xm8's Avatar
xm8
If the AEM F/IC comes with a harness, then why did you do all the soldering?
Old Dec 25, 2010 | 01:13 PM
swflej1's Avatar
if the harness looked anything like a radio harness then soldering is a better way of doing it then using bud connectors.
Old Dec 26, 2010 | 11:53 AM
mole177's Avatar
is there a thread or picture of the weapon r header?
