Help with Pivot 3 Drive throttle control. urgent.
Old Dec 20, 2010 | 07:51 AM
Azizul Zulzaha's Avatar
hi,
i have recently installed an throttle control unit.
the brand is PIVOT.
it is the Pivot 3 Drive throttle controller.
you may read about it here:
Pivot 3-Drive Throttle Controller 2010 - Product Review - Pitstop Singapore
THE PROBLEM:
after i have installed the item (pivot 3 drive throttle controller), i went to another shop to install some grounding wires, the connecting wire to my car's battery was removed in order to install those grounding wires. the technician said, later i have to start the engine and let it re-learn stuff, since it has been soft-reset.
my question:
do i need to calibrate the Pivot 3 Drive throttle controller?
because, when installing the item, it seem it has to be calibrated...
or i just continue use like normal...
Old Dec 20, 2010 | 07:56 AM
ej20i's Avatar
u need to re calibrate everytime it looses connection
so when the battery comes out, it lost its memory, but in saying that, if you could drive home den its fine
but it doesnt hurt to re calibrate it
takes like 2 mins
Old Dec 20, 2010 | 08:58 AM
takes like 2 mins
the manual is written in japanese, is there any comprehensive way to re calibrate it?
please give me some guide...
Old Dec 20, 2010 | 12:11 PM
GD3_Wagoon's Avatar
if i remember right, to reset/recalibrate the ecu you just start your Fit and let it idle till the radiator fan cycles on and off twice. i did this when i installed and uninstalled my intake, it's a piece of cake
Old Dec 20, 2010 | 01:41 PM
Virtual's Avatar
What is so urgent about this?
Old Dec 20, 2010 | 06:24 PM
not talking about the ecu and intake.
talking about the throttle controller.
Old Dec 20, 2010 | 06:25 PM
want to test it on the highway...
Old Dec 21, 2010 | 02:58 PM
ej20i's Avatar
i believe it was hold down MODE until it counts down to zero den press set. den floor the gas pedal and den press set and thats it
Myxalplyx
Oct 20, 2014 03:30 AM
modfit669
Dec 27, 2009 03:24 AM
FELIXY69
Nov 16, 2009 11:28 AM
da9r00d
Jul 21, 2009 01:24 AM
FELIXY69
Nov 20, 2008 07:07 PM
