Need Engine Help ASAP PLEASE!
Old Jan 11, 2011 | 10:07 AM
TFREEfit's Avatar
So recently there has been a sound coming from under my hood. When starting the car (sometimes) you can here this little rattle sound for a few seconds. While driving the car especially in higher rpms this rattling sound becomes louder and more noticeable. it sounds like a rattleing / knocking but i highly doubt its the engine knocking. What could possibly be making this sound? and will the dealership check it out for free? other info: I have done a few bolt ons and the car has 17k miles. thanks guys
Old Jan 11, 2011 | 10:27 AM
onemiglandicho's Avatar
They should be able to check it for free. Are you absolutely sure that none of your bolt-ons are loose thus making the sound? Check first as it may be as simple as some of your installed items is/are loose.
Before heading to the dealership, check everything including vital fluids for proper level so as to minimize the things they can blame on you.
Old Jan 11, 2011 | 10:32 AM
zymo's Avatar
what kind of bolt ons are we talking about? hopefully nothing that would void your warranty.
Old Jan 11, 2011 | 05:55 PM
TFREEfit's Avatar
CAI & a full exhaust from cat-delete to tip
Old Jan 11, 2011 | 07:05 PM
Before heading to the dealer, it's probably best to put the catalytic converter back on.
Old Jan 11, 2011 | 08:21 PM
thaduke2003's Avatar
Whenever ANY decent mechanic looks at a NVH issue with a modified vehicle, the first thing they'll look at is the modifications. Usually, they're done at home, and people screw up. Also, aftermarket parts are often as not of lower fit/finish quality than OEM, so they're much more likely to cause issues.
Check your work on the intake and exhaust. Check for something loose, which is where 95% of rattles come from.
Is it a metallic (metal-on-metal) tapping/knocking? Or perhaps plastic-on-plastic? The type of sound should help lead you to the issue. The fact that it's more noticable at higher RPM (does it increase with VEHICLE speed as well?) and start-up means it's PROBABLY engine-related (auto or manual trans, by the way?). If it happens ONLY when in gear, it's PROBABLY transmission related. If it's only out of gear, you can PROBABLY rule out the trans.
More info=better diag. Noise complaints are often hard to diagnose in person, and over the internet, VERY hard. Find EVERY condition that effects/changes the sound, and post up your findings. It's likely you'll find it on your own, which is halfway my aim Mark W.
Old Jan 11, 2011 | 09:50 PM
TFREEfit's Avatar
So Ive done a little research and i was thinking that it might be because of the cat delete. It could be because of a loose bolt but i think its because the heat shield?
Old Jan 11, 2011 | 09:56 PM
TFREEfit's Avatar
ive been trying to. just need the tools :/
Old Jan 11, 2011 | 11:27 PM
Loose heat shielding is about 1 in 3 rattles, in my experience, especially in areas where there's salt/sand on the road- Mark W.
Old Jan 12, 2011 | 01:12 AM
DiamondStarMonsters's Avatar
Both contain some good advice.
Also consider reverting back to stock entirely where possible before going to the Dealership..
Old Jan 12, 2011 | 07:35 AM
TFREEfit's Avatar
Well i have driven a significant amount in BOTH salt and sand, I also have a cat-delete soo i think that might be the problem. I will be going back to stock with the next couple of days and hopefully that works..
wackyflik
Jul 24, 2014 01:25 AM
wackyflik
Apr 30, 2013 12:44 AM
get_FIT
Oct 26, 2010 12:34 AM
klara
Feb 24, 2007 11:49 AM
chibitul
Aug 7, 2005 12:38 PM
