Weird sound front
Old Apr 21, 2013 | 09:03 PM
wackyflik's Avatar
Weird sound front
I have been haunted a sound like 'kluk kluk' from the right front side of my gd1. After a long hours checking where was the sound coming from, in the end my mechanic and I found its location. So, I changed my lower arm and stabilizer link and the 'kluk kluk' sound is gone. I am happy for that. Next, I drive my car for the whole last week and I did notice there is another sound coming from right front side as well. But this time the sound is very light and not too loud as before. Need to off my radio then I could hear the sound. The sound only can be heard when I hit any holes on the road with high speed like 100kmh. My mechanic suspect my mounting absorber caused the problem. My question is, does the mounting absorber produces any sound if it has problem?
Old Apr 22, 2013 | 03:36 AM
loudbang's Avatar
Fits and Jazz have a small problem with wearing out the strut cap rubber coatings on the cap that goes on the top side of the strut in the enginebay.
Put your wheels straight ahead pop the hood and look at the top of the strut where it comes up through the body.
Just below the nut holding the top part of the strut on there is a round part about 2" in diameter with a rubber "cover" on it with ribs on it.
When the car is level with wheels straight ahead there should be very little clearance between the bottom of the rubber cover and the body.
If the clearance is larger like OVER 1/4 inch or so you will get a clunking when going over bumps.
The part I'm talking about is called the "damper mounting base" in this photo.
You must use IE to see the photos. Click in the small grey boxes to see them.
to see this part click the "exploded View" blue link right at the top.
Front Damper/Spring Replacement
Old Apr 22, 2013 | 07:11 AM
wackyflik's Avatar
Thanks loudbang. Is it similar to stabilizer bar bush or absorber mounting?
Old Apr 22, 2013 | 09:47 AM
Marrk's Avatar
Very interesting (and clearly stated), loudbang.
Got a page number in the Service Manual for this . . . ?
Again, thanks.
Old Apr 23, 2013 | 12:05 AM
loudbang's Avatar
No sorry I don't have a hard copy manual but it should be under suspensionin the index of one.
Old Apr 23, 2013 | 12:07 AM
loudbang's Avatar
It's just the "cover" on top of the strut that prevents it from falling back into the wheelwell through the hole in the body and cushion the body from taking a beating from strut movement.
Old Apr 29, 2013 | 09:21 AM
wackyflik's Avatar
I changed the damper mounting base unfortunately still hear the sound if I hit potholes on the road with high speed. Not really high speed even if I drive about 60 - 70 kmh still hear the sound. My Mugen Sport Absorber is functioning well, except one thing, I notice my coil spring does not has its rubber sleeve. Anyone here using Mugen Sport Absorber/Suspension? Does your coil spring has rubber sleeve?
Old Apr 29, 2013 | 11:38 AM
mahout's Avatar
We've seen that here but surely it would result in knocking even if thed clearance is less than 1/4", likely if its loose at alll. Would using a metal ewasher or two under the strut nut tighten the cup into the body?
Old Apr 30, 2013 | 12:24 AM
loudbang's Avatar
No there is a shoulder on the strut top to prevent over tightening. I saw somewhere where a guy bought new tops that were cheap then tore off the rubber part and glued it underneath the original cap to take up the extra space.
Old Apr 30, 2013 | 12:44 AM
mahout's Avatar
Thats what I was describing, washers under the old cap & between the body cavity. I'd be tempted to rivet them rather than gluing.
Yeahhhok
Jun 21, 2018 12:31 AM
kaikou
Oct 22, 2015 03:19 AM
toomuchjoy
Jun 10, 2012 09:31 AM
get_FIT
Oct 26, 2010 12:34 AM
klara
Feb 24, 2007 11:49 AM
