Problem!!:(
Old Mar 18, 2011 | 10:42 PM
ian-white's Avatar
Arrow Problem!!:(
I just bought a intake from a great guy and he had a mt and had no problem but i have same model fit but mine is at and my trans. is slamming into the next gear as my exhaust is smelling X2 as bad and bold what can i do???
Old Mar 18, 2011 | 11:53 PM
jdmjunkie561's Avatar
Damn that sounds weird ! I wonder why! Sorry dude and good luck
Old Mar 19, 2011 | 12:23 AM
john21031's Avatar
Put the original back on?
Old Mar 19, 2011 | 12:40 AM
Honestly dude I would if its giving u problems like that and I would do my research on, if there is a difference between getting it for a stick compared to a auto! It just doesn't seem right
Old Mar 19, 2011 | 08:05 AM
rhyneba's Avatar
I presume you have the same gen Fit as the MT. Is the check engine light on? If so, go to Autozone or Advance Auto and have them pull your codes for free and post them. In the interim make sure your mass-air sensor is properly fitted and connected, if it is, remove it and check inside the sensor for an insect or other contaminant. The end of the sensor is very delicate, don't use tools or anything hard to clean it, compressed air is usually all it takes. Check your clamps, if any are loose the car will pull in unmetered air. Also, check your vent tube from the valve cover to the intake for the same reason.
If all else fails swap your stock airbox back and see what happens. If this "great guy" is around, see if you can swap your mass-air out with his and check it.
Hope this helps.
b
Old Mar 19, 2011 | 12:32 PM
ian-white's Avatar
well as of right now i changed something and it is running great just my check engine light is on :/
Old Mar 19, 2011 | 01:18 PM
Its Ok it happened to me too ! Just disconnect the battery for 30 sec and connect it again and the check engine light is gone! It turned in cause of the sensor but u didn't really do nothing with it so jut reset it
By doing what I just told u
Old Mar 19, 2011 | 01:50 PM
Farther's Avatar
If you are going to disconnect your battery, have your radio codes handy.
Old Mar 19, 2011 | 02:31 PM
ian-white's Avatar
i know right i had to call honda and have them get them because they failed to give them to me..... fail
Old Mar 19, 2011 | 07:14 PM
rhyneba's Avatar
Your radio code should be on the first page of your Service History book, on your radio code card and on a sticker in the glove box. If you can't find those you can force the radio to display it's serial number by pressing the "1" and "6" preset buttons down with the radio off and while holding them down turn the audio unit on. The serial number will show on the display. PM me the number and I'll get you your radio code.
b
Old Mar 19, 2011 | 11:38 PM
ian-white's Avatar
b
Yea they didnt have a sticker on the glove box but i did find it in the book. thank you man you have been a big help!!!
Jutboy
15
May 16, 2024 07:11 AM
MTLian
Apr 10, 2014 05:37 PM
bigtoepfer
Apr 5, 2011 10:04 PM
xcurt15
Jul 5, 2007 04:49 PM
Scott Rogers
Aug 19, 2005 06:48 PM
