L15A Head with R20 Block
Old Mar 20, 2011 | 01:29 PM
jevin09's Avatar
may i know can the above combination fit together>>??
Old Mar 20, 2011 | 03:14 PM
kylerwho's Avatar
spoon fed
the physical size of the l15a7 head is to small for the r series block. the head bolts dont line up. at least that is the way the l15 head sits on the r18 block.
Old Mar 21, 2011 | 12:37 PM
jevin09's Avatar
u mean it can fit on a R18 block instead of R20??
Old Mar 21, 2011 | 03:28 PM
kylerwho's Avatar
spoon fed
im not sure about the r20 but it will not work on the r18 block.
Old Mar 22, 2011 | 11:15 PM
Lyon[Nightroad]'s Avatar
the l15a7 head doesn't even match up with the original l15 block due to a revised coolant jacket...
Old Mar 28, 2011 | 11:37 AM
jevin09's Avatar
any idea does any block that suit our L15a?
Old Mar 28, 2011 | 01:44 PM
This isn't like the olden days when you would swap out your ancient 95 'stang 4.6 heads for some 03 PI Heads or swap an 'exploder' block.
Old Mar 28, 2011 | 03:11 PM
kylerwho's Avatar
spoon fed
your only bet is to sleeve the l15a and bore it out to increase displacement. i have been looking into running a d-series crank in the l15a but i dont know if it will work or not yet.
Old Mar 29, 2011 | 09:00 AM
jevin09's Avatar
do update if able to combine the setup...
H22a1Prelude
18
Dec 6, 2021 12:55 PM
noamGE8
Aug 5, 2020 02:26 AM
noamGE8
Oct 6, 2014 03:57 AM
Sugarphreak
Oct 16, 2013 12:37 AM
kenoshainflames
17
Nov 8, 2008 03:09 PM
