Anyone have this hood deflector/protector?
Old May 8, 2011 | 12:52 AM
Blackberry Goose's Avatar
HONDA FIT Smoke Hood Shield Bug Guard Trim 2009-2011 | eBay
I dunno about using double sided tape on the hood............
Old May 8, 2011 | 01:13 AM
solbrothers's Avatar
that looks cheesy as hell. if anything, get a clearbra
Old May 8, 2011 | 01:22 AM
The AVS aeroskiin attaches the same way...must be new style of doing things ie: cheap
Old May 8, 2011 | 01:35 AM
score04w's Avatar
not feeling the 3m stick on kind. What solbros said, looks kind of cheesy.
Old May 8, 2011 | 10:42 AM
Ultrawolf's Avatar
I came across what appears to be the same deflector at Advance Auto Parts - cheaper than ebay too. If you get it there it should be an easier return if you don't like it.
If this link doesn't work, search for part number 32003, "Aeroskin Hood Protector, Smoke":
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Aeroskin-Acrylic-Ventshade_10014222-P_1041_R|GRP60004_1534896075___
Alternatively, I have a Magnetbra that I'm still very happy with: https://www.fitfreak.net/forums/2nd-...protector.html
Old May 8, 2011 | 11:54 AM
Iamnotkento's Avatar
get the oem one. looks way better
Old May 11, 2011 | 01:57 AM
TheOrangeRevolution's Avatar
AVS has always done everything the cheap-o, adhesive way, haven't they? I know their "world famous" window shade things are the stick on type and not the in-channel stuff like WeatherTech.
Old Dec 27, 2011 | 04:40 PM
littleblackcar's Avatar
The thing about a deflector is it can't be removed, right? Because of the adhesive? Are you still liking the magnet bra, and is that easily removed?
Old Dec 28, 2011 | 07:56 AM
Ultrawolf's Avatar
I've had the Magnetbra on for two summers now, and still have no complaints. You can remove it in a couple of minutes. Re-installing might take 5-10 minutes to get it lined up just right. I choose not to use it during winter because I'm concerned about road salt/spray getting under it, plus you don't have warm temperatures to bake out any moisture that might get under it, especially around the plastic edging.
Old Dec 28, 2011 | 09:27 AM
Are there any problems with it in the rain, or rather, after it rains? Does it have to removed to dry it? Thanks!
Old Dec 28, 2011 | 12:02 PM
Ex-MA Hole's Avatar
I have the stickon one that the OP asked about...It's been on for about a year and 3/4's....40,000 miles...no movement, no condensation, it, to me, looks good.
Would I do it again? Probably....It's not great, but it does protect the nose of the hood....
Old Dec 28, 2011 | 06:02 PM
Ultrawolf's Avatar
I don't remove the Magnetbra after it rains. It doesn't seem like water gets between the bra and the hood, but a little water does collect in the "C" shaped edging. But at summer temperatures, the edging dries out after a day or two without removing it - I've pulled it off to check.
zetaproducts.net
Oct 4, 2010 01:25 PM
zetaproducts.net
Zeta Products.net
Jul 29, 2010 02:06 PM
AlphaQuad
Apr 27, 2010 12:28 AM
TekXoID
May 6, 2009 08:43 AM
mugenpower88
Nov 12, 2008 02:37 PM
