Changing wiper blades
Old Jan 29, 2012 | 12:49 AM
Shockwave199's Avatar
Just picked up new OEM inserts from ebay. All rubber. The originals have a solid silver bracet to the back. Do the inserts go on that, or am I missing something? Seems like an all rubber blade isn't good.
Old Jan 29, 2012 | 01:36 AM
macbuddy's Avatar
Here is what I did...
When changing the wiper blades on my GD3, I merely removed the metal inserts from the OEM wiper blades, and reuse them with the new refills. Sounds like your "solid silver brac(k)et to the back" rubber blades weren't OEM. Those OEM refills from ebay require those metal inserts to install.
Old Jan 29, 2012 | 01:42 AM
Krimson_Cardnal's Avatar
All rubber - they slide into the metal bits.
Old Jan 29, 2012 | 02:04 AM
Thanks for that. They said I needed them at inspection last summer but frankly, they're fine. They're old enough to change but aren't acting worn out.
Old Jan 29, 2012 | 05:28 PM
wetphoto's Avatar
Ypu mean the State tells you to replace your wiper blades? I thought NY was part of America. Guess I was wrong
Old Jan 29, 2012 | 09:08 PM
No, that was dork Rick Perry who wanted texas to sucead from the union, not NY. We're still part of the gang.
Not sure if it's a check point thing, but I suppose it's a saftey issue so why not. Maybe they were just looking to make a few bucks more and push blades on me. But it didn't happen because they didn't have anything that matched so they just said I should get new ones along the way. Been going to them for years- they probably just noticed and said I should. I suppose the blades are somewhat worn- it'll be 3 years soon. But they work fine to me.
Old Jan 29, 2012 | 09:58 PM
It is a safety check and they did right by pointing the need out to you. Nice to have friendly service watching out for you.
Old Jan 29, 2012 | 10:09 PM
wetphoto's Avatar
What happened to taking care of yourself, without the need for big brother to micro-manage your life?
Old Jan 29, 2012 | 10:46 PM
Micro managing would have been failing the car because of it. Urging me to change them out asap and passing the car is...letting me take care of it myself.
Old Jan 29, 2012 | 10:52 PM
wetphoto's Avatar
So they suggested instead of ordering you to do it? in that case fine. I recall when I was in Oklahoma, they failed you for anything, including headlight alignments. Even a brand new car would always fail, and you had to pay them to adjust, or no license.
Old Nov 6, 2014 | 02:37 PM
prhkgh's Avatar
Suggesting the replacement wiper blades when worn is a good thing...if you are in the car that gets hit because the other car's wipers weren't doing their job in a downpour! :}
Old Nov 6, 2014 | 07:27 PM
specboy's Avatar
NJ, PA, VT are all the same way (many other states are this way as well - these are where I have lived). you have to have wipers that will wipe away water or your car won't pass inspection. It's more for the safety of others than it is for your own personal safety. Part of the problem is that too many people barely know how to do anything more than turn the car on, let alone know how to periodically inspect their cars or perform routine maintenance. Sometimes, it's because they are ignorant about cars (and may not have the mechanical aptitude for automotive maintenance), sometimes it's because they are just stupid. It takes all types to make the world go 'round... And last I checked, the world is spinning just fine!
~SB
Old Nov 10, 2014 | 01:51 PM
you talking about the two long thin metal strips that run along the side of the refills? if so you will reuse them from your stock blades.
Old Nov 12, 2014 | 09:12 AM
rvd9431's Avatar
Yes reuse metal strips when replacing rubber you have to. I replaced my rubber recently way better than wasting money on new wipers
Gregg
Jun 22, 2012 06:45 PM
kakrohn
May 7, 2012 11:26 AM
gmalone
May 29, 2011 02:52 PM
FitNYC
Mar 23, 2011 03:24 AM
Gordio
Sep 10, 2008 03:43 PM
