Please help with TSX Homelink install on a GE8 base
Old Feb 13, 2012 | 04:16 PM
MOTOMATT's Avatar
Question Please help with TSX Homelink install on a GE8 base
Quote:
Originally Posted by Zalthras
Harness Wiring
Connections that need to be made, two of which are pin transfers from the TSX maplight:
First we’ll start with the wiring connections that will be made between the Homelink and Maplight units themselves (Chassis GND & Intermediate GND). Flip over the maplight you just removed from your Fit.
Now put everything back together.
***IMPORTANT - Remember that the Homelink’s GND is through the mounting bolt, so test after the base is bolted back into the ceiling***
Do I connect TheTsx homelinlk Grn/red and green to the fit Blue switched ground wire ? or where do you connect the Tsx homelinlk green wire to
Thanks for any help.
__________________
Old Apr 21, 2012 | 11:15 AM
Gaujo's Avatar
bump, just got mine as well, I have no idea, and I think I'm even worse off as I have no harness included!
dela
94
Aug 31, 2023 12:04 PM
MSF1T
California - Bay Area Community
Aug 31, 2018 12:08 AM
Jay_e8
Dec 28, 2017 09:04 PM
Orie
Jun 19, 2013 07:50 PM
-hurley18
Oct 24, 2011 02:19 PM
