How are you guys getting 38 miles per gallon
Old Oct 2, 2015 | 07:52 PM
  #81
WindingRoad's Avatar
I average 36 mpg using A/C and 38 without. I always coast down for freeway off ramps.
Old Oct 2, 2015 | 09:53 PM
  #82
Just coming in to say that on my new commute I only average 40.....
In stop & go traffic the entire way, regularly sitting through a red light three or four times before I can make my left turn.
Old Nov 18, 2015 | 02:47 AM
  #83
Fitsme5312's Avatar
Originally Posted by Brain Champagne
Think of the brake pedal as a direct link between your bank account and Saudi Arabia.
LOL. Awesome. +1
Old Nov 18, 2015 | 01:46 PM
  #84
Dominic49's Avatar
The dash is a lie.
2009 Honda Fit MPG TSB 09-086 - Documents
See attachment for my actual comparison of Trip Computer MPG vs measured MPG
Attached Thumbnails How are you guys getting 38 miles per gallon-screen-shot-2015-11-18-1.44.40-pm.png
Old Dec 7, 2015 | 12:33 PM
  #85
willoughby's Avatar
I don't know how you guys can achieve a respectable 40mpg. I, on average, get about 12km/L which is roughly 28mpg. The best I've done was about 32mpg. Never managed to achieve the advertised 20.5km/L (48mpg).
Old Dec 7, 2015 | 01:04 PM
  #86
Fitsme5312's Avatar
Wow, I've never achieved lower than 30 MPG. I always use regular gas and my car is stock. If you want more corroboration, check out Fuelly - Track and Compare your MPG. I track my car's MPG there and I notice that there is a noticeable (5-10%) decrease in my MPG during the winter; it's probably because of the anti-icing/anti-freezing fuel additives.
Inflate your tires to 35 PSI. Go easy on accelerating from stops.
Old Dec 7, 2015 | 02:59 PM
  #87
Desmond Lamar MacRae's Avatar
I pump mine 36psi with NO2 (Nitrogen) and get 38 to low 40 mpg. Next thing I do is 1 step cooler spark plugs and 93 octane= 10 more hp and squeezing out even more mpg. It also depends on elevation changes lowers mpg. I live in Eastern NC. Things are at or under sea level. When I travel it's either I-40 or I-95 which stays flat. Good luck to you.
Old Dec 7, 2015 | 04:15 PM
  #88
Fit Charlie's Avatar
How's Hong Kong traffic?
Old Dec 7, 2015 | 07:35 PM
  #89
Txfitish's Avatar
I drive 82 miles a day, I get between 36-38 on 93octane with just a Kn drop filter.
Old Dec 7, 2015 | 09:39 PM
  #90
tj5436's Avatar
38+ mpg
I use bridgestone etopia tires made for fuel milage, and I keep them at about 38 Psi. I utilize a high flow K&N air filter, but I utilize the original air box. Sometimes I use a non ethanol gasoline. I do see numbers in the low 40's with use of a non ethanol gasoline. Above all else I am driving at the posted limit, or 5 below. If it is dark out, raining, etc... I will keep to the right lanes, and not afraid to follow trucks. I use cruse control!
I noted a fuel milage increase with the use of Michelin Energy tires, and a higher increase with the current Bridgestone, Etopia tires. I do courier work and keep the car in great condition. Oh, and I use the highest gearing possible. I have a M5 transmission.
Old Dec 7, 2015 | 10:23 PM
  #91
willoughby's Avatar
often stop and go. Too many traffic lights. Speed limit on city streets is 50kmh. Highway/Expressway - 70 to 110 depending on where you are. Mostly 80kmh. You never go more than 30 mins of highway driving before you hit a traffic or a traffic light.
the psi on my car is at 34 (cold). The gas here is a minimum of 93 but costs roughly HKD14.45/L (Cost about 500HKD ($65USD) to fill up my tank).
I rarely turn on the AC if I'm the only one in the car.
Old Dec 8, 2015 | 07:31 AM
  #92
Stop & go with too many lights = bad mileage.
A good day for you is when it sucks less, getting better numbers than you normally do.
Old Dec 8, 2015 | 08:41 AM
  #93
Isaac513's Avatar
From what I recall, I've been seeing 40 mpg @ 65 mph, 33@75, 25@90. Flat highways, sea level, K&N drop-in filter.
Sticking to speed limits and leaving early for work help lol
Old Dec 8, 2015 | 11:21 AM
  #94
dlivry7's Avatar
it all depends on where you are driving and if you need to use ac/defrost on a regular basis.
stop and go, mpg is going to drop, under 65, and not so much stop and go, and nothing special is required to achieve 40mpg
Old Dec 8, 2015 | 01:04 PM
  #95
Txfitish's Avatar
awesome info.
scraggles
May 5, 2014 06:23 PM
kennef
Apr 23, 2010 01:21 AM
Hondadaddy
Jul 15, 2008 09:28 PM
fitofrage
Apr 15, 2008 12:19 PM
Shahul@HersonsHonda
May 18, 2006 10:29 AM
