B-Spec Kit Components
Old Apr 15, 2012 | 08:52 PM
BlueBoogers's Avatar
Now, Honda has announced their line of "manufacturer-approved suspension components." For $2,800 you'll get coil-over shocks, camber bolts, braided stainless brake lines, an air filter, front and rear race springs, a cat-back exhaust, front brake pads and an A/C delete belt. The kits will be available on 2/1/2012 through HPD.
Does anyone know who makes the coilovers and whether or not the brake pads are street or race compound?
I may go ahead and buy the $2,800 kit and not use the A/C delete belt.
Old Apr 15, 2012 | 09:22 PM
Funkster's Avatar
I believe struts/shocks built by Bilstein and the springs done by Eibach. Both obviously with the help of Honda Development.
Old Apr 15, 2012 | 09:23 PM
^ Ooh, that would be good. I'm curious about the pads still once we have confirmation of the coils.
I wonder if the car is streetable after this kit is added.
Old Apr 15, 2012 | 09:25 PM
krunk13's Avatar
I dont think you can buy it unless your a race car driver. Honda requires that you be part of a sanctioned racing organization and that you provide results from your last two races for you to order from HPD.
Old Apr 15, 2012 | 09:26 PM
Funkster's Avatar
I only thought there were SS brake lines. I didn't know there was pads?
Old Apr 15, 2012 | 09:27 PM
Do you happen to have any sources for this info?
I can always build a better kit but it would be neat to throw down and get off to a great start with the next Fit.
Old Apr 15, 2012 | 09:29 PM
kylerwho's Avatar
spoon fed
These are all built by Honda in house. Brake pads are race compound due to the fact that the kit revolves around racing in the B-spec class.
Honda Performance Development, Inc. to Begin Sale of Performance Parts for Racing ~ Honda Performance Development
Old Apr 15, 2012 | 09:33 PM
ThEvil0nE's Avatar
It's a standard practice.
Old Apr 15, 2012 | 09:36 PM
Funkster's Avatar
I am looking for the source, but I read it on a Honda affiliate site for sure as well.
Old Apr 15, 2012 | 09:40 PM
That's too bad. Back to the drawing board!
Old Apr 15, 2012 | 09:43 PM
krunk13's Avatar
Old Apr 15, 2012 | 09:49 PM
Good call. Time to piece it all together myself again.
Old Apr 15, 2012 | 09:57 PM
ThEvil0nE's Avatar
I like this route better
Old Apr 16, 2012 | 01:57 AM
wontfit's Avatar
it sure will be cheaper...
Old Apr 16, 2012 | 07:39 AM
Chad T's Avatar
The coilovers can be had for $1100. $1700 seems like a lot for the rest of that stuff.
Old Apr 16, 2012 | 08:43 AM
krunk13's Avatar
Can be had where?
Old Apr 16, 2012 | 09:30 AM
x_25's Avatar
Can be had where?
If it is the bilstien ones, tire rack has them.
Old Apr 16, 2012 | 12:06 PM
Chad T's Avatar
Can be had where?
I got mine here. Bilstein 47-165854 Performance Suspension System | AJUSA.com
Says they are out of stock now. I actually paid $1030 shipped when I got mine. Just do a google search for bilstein 47-165854 and you will be able to find your best price.
I also got camber bolts at jegs but I think they were only around $35.
BTW these coilovers are awesome.
Old Apr 16, 2012 | 01:17 PM
phenoyz's Avatar
Chad T ----how is the ride w/the bilstein? how about with passengers?
what's ur wheel/tire specs?
thanks
Old Apr 16, 2012 | 01:30 PM
FIT4thetouge's Avatar
Those Bilsteins aren't even close to the same spring rates as the ones you would get from the B-spec kit keep in mind...they probably have much stiffer valving as well.
