Baffle me please!
Old Apr 17, 2012 | 02:06 PM
Chitownfit's Avatar
Baffle me please!
I had to order a replacement oil pan cause of a tow and wanted to baffle it.
Any ideas?
Old Apr 17, 2012 | 02:18 PM
Wanderer.'s Avatar
Cut sheet metal, weld in baffles.
Old Apr 17, 2012 | 02:42 PM
Chitownfit's Avatar
Guess I should've also asked if anyone on here has done it?
Old Apr 17, 2012 | 03:13 PM
Funkster's Avatar
Order a baffled oil pan?
I am sure if you call up a shop like Mororso, etc they will sell you a custom baffled pan.
Old Apr 17, 2012 | 05:50 PM
555sexydrive's Avatar
Spoon has one for the CR-Z, but not the GE8. I asked if they planned on bringing one out, but they wouldn't say yes or no.
Old Apr 18, 2012 | 12:18 PM
mahout's Avatar
Its not that simple.
Old Apr 18, 2012 | 02:11 PM
Wanderer.'s Avatar
Make something like this, it doesn't even have to be that crazy with the cylinder part hanging down like that.
You're not doing 2g sweepers at 9k RPM, I think a simple baffle would be fine for most AutoX or road race people on here.
If it were me, i'd take it to an experienced race shop and have them do it. I'd rather pay once than buy another pan because I screwed up welding/warped the pan
Old Apr 18, 2012 | 02:51 PM
DiamondStarMonsters's Avatar
An improperly made baffle can make problems worse.. far worse.
Old Apr 18, 2012 | 05:42 PM
mahout's Avatar
I agree with going to an experienced race shop. Your sump appears to be a small cup in the bottom of the sump. Its a good idea but did you calculate the amount of oil that would remain in the cup in a 0.8 g turn?
If the cup is shallow enough the oil will pour over the side and potentially let air in the pump.
A better method is walling the oilpickup such that its almost impossible for the oil to get out as in a double opposing 'u'. thats just the start.
Old Apr 18, 2012 | 05:52 PM
Wanderer.'s Avatar
Pic was stolen from a Japanese speed shop blog (old one at that 2002ish I think haha), I just used it because it was DIY and fairly simple in design.
I'm glad this discussion is moving in a good direction. I wouldn't mind doing some baffles in the future after my car is retired from DD status, so any knowledge gained is good. Thanks
Old Apr 18, 2012 | 09:31 PM
Chitownfit's Avatar
I'm looking at that oil pan and it doesn't even look remotely like the one for a GD3. :-D
At this point I'm not sure if even taking it to a race shop in my area will do any good. If they don't know the car or how the oil will react in a race how can they baffle it properly. Spoon must have done this. I just wish I could see a picture so I've got an idea of what it needs to look like.
Thanks for the reply's though. They are much appreciated!
Old Apr 19, 2012 | 02:47 PM
Wanderer.'s Avatar
Here...
That's the Spoon Pan for the CRZ, so like the GE pan, L15A7, IDK how different the L15A1 pan is, but maybe you can take the concept and run with it.
Old Apr 19, 2012 | 02:57 PM
Chitownfit's Avatar
Wow. I can't see any difference at all! Exactly what I was looking for. Thanks man!
Old Apr 19, 2012 | 03:04 PM
Wanderer.'s Avatar
No problem, good luck, I hope you're able to come up with something so I can copy you later
Spooling
Aug 12, 2024 01:13 AM
Mister Coffee
24
Mar 17, 2024 12:54 PM
Skwigelf
Apr 27, 2016 11:47 PM
einstein77
Dec 27, 2011 09:34 AM
smeister
Mar 10, 2007 01:50 PM
