Need HELP! Car just unexpectedly just died in the highway.
Old May 5, 2012 | 07:50 PM
Unreal12's Avatar
Fellow freaks, as the title states, after having the gas light on, i pull up to a gas station for a fill. immediately after departing i would say 5 min after turning in off an underpass the car bogged and turned off after turning left. My battery light and oil light came on.
I tried to start it, nothing, i tried again and it turned on with a little trouble and everything stabilized if you will.
I checked the oil and it is fine and the car is running fine, for now.
My question is, what could it be? I have OCD and this will drive me crazy and I dont want to get stranded and have to pay a tow truck or something. Any suggestions please.
I've had the car for about 2 years now and never experienced any issues, always done my maintenance on time.
Current mods: 300w rockford amp with sub (had it since the second month i owned the car), and K&N intake (less than a month old).
thanks guys, i appreciate any input!
Old May 6, 2012 | 01:12 AM
fittacular81's Avatar
Could be your battery.......
Old May 6, 2012 | 02:57 AM
thefit09's Avatar
I'm no expert, but it sounds like you could have run the tank and fuel pump too dry. I have heard it's not good to let the tank get too low because it puts extra stress on the pump.
For those that actually know what they're talking about, could this be it?
Old May 6, 2012 | 05:49 AM
Black3sr's Avatar
Running tank down to warning light and OCD? Wow
Try filling up before the warning light comes on. Likely sucking up any crap in bottom of the tank.
I fill up around half a tank or 1/2 minimum.
Old May 6, 2012 | 09:59 AM
krunk13's Avatar
^ what he said. The fuel in your tank cools and lubricates the fuel pump. Its not good to run it low and suck up dirty fuel.
Old May 6, 2012 | 10:21 AM
Unreal12's Avatar
In reality I have OCD for my car breaking down, and it stalling on me fucking drives me wild. a gas light never bothers me and to be honest, I've had the gas light on and drove 30 miles with ease and filled. Maybe this time it picked something up from the bottom when it stirred. maybe you guys are right, i was worried my alternator is giving out and not charging the battery because of my sub and amp.
any input on this theory?
Old May 6, 2012 | 10:22 AM
malraux's Avatar
its pretty easy to get your alternator tested at major auto parts stores.
Old May 7, 2012 | 10:19 AM
smaglik's Avatar
my guess is you overheated the fuel pump, although it does seem odd that it would stall after filling up. as has been said, fuel in the tank cools the pump.
And relax. Cars are complicated pieces of machinery. Even the most reliable ones break from time to time.
Old May 7, 2012 | 01:52 PM
jzerocsk's Avatar
There's at least a gallon in the tank when the light comes on...that's not going to kill the fuel pump. Refilling around 1/2 the tank is crazy with a 10 gallon tank. I'd be refuelling every other day!
Old May 7, 2012 | 02:06 PM
DiamondStarMonsters's Avatar
Have you seen the physical shape of the fuel tank and where the pump is situated in the hangar?
Old May 7, 2012 | 02:32 PM
Steve244's Avatar
Hondas are reliable. Your OCD is why you bought one and not a Hyundai.
Your description (or my reading) isn't clear; does the starter motor not turn the engine? If not, then your sub-woofer mods are at fault, or your battery died (they do this the 1st hot day of the season just to annoy us), or both. The Fit's battery isn't made for deep discharge/charge (for many cycles).
If the starter engages and turns the engine fast enough to start, but it doesn't fire, then maybe you got bad gas or your intake is at fault.
Don't forget to tell us.
overheating fuel pump? This isn't a ford.
Old May 7, 2012 | 02:33 PM
smaglik's Avatar
Hmmm...so the fuel pump is invincible, eh? Awesome!
Old May 7, 2012 | 02:52 PM
Punisher11's Avatar
ill bet battery.
i stopped on the side of the road (my dads truck who i was following got a flat), with hazards on AND my phone, gps and bluetooth charging, engine off. Car dies after 20min.
Pull out all the electronics, sit for 20 min, gets enough juice to spark and turn over. Open the hood and the battery indicator is blue (first time i seen that), charged it, indicator goes green, replaced in car and is good to go.
muffins
Aug 13, 2014 09:48 AM
Unreal12
May 5, 2012 07:44 PM
Evan_2k
Aug 20, 2009 12:51 AM
trancedsailor
Jan 30, 2009 11:45 AM
DOHCtor
Oct 26, 2008 06:26 PM
