Just ordered wheels...tires?
Old May 23, 2012 | 07:50 PM
FIT-tles Worth's Avatar
ok just ordered my wheels 17 x 7 et47 (Work XD-9 WHT)
i am curious what size tires i should go with? i saw that EvilOne used 195/45/17 Yoko S-Drives, but in this size i cant find anyother brands?
What size tires should i use? and which brand...? i was going to go with Dunlop or Conti's but they dont have 195/45/17
Any help would be appreciated. I am also going to be lowering the car when i receive the T1R coilovers...
Old May 23, 2012 | 07:59 PM
Why not use S.Drives? They're a great daily driven tyre.
bigpun54's Avatar
I'm on the same boat as u hommie....sorry for the thread hijack..... I'm gonna drop my fit on Tein s techs and throwing some 16x7 40 offset rotas on but I'm wondering which tires size I should go with....I don't want them to rub so should I go 205/45/16 or 205/50/16.
Old May 23, 2012 | 08:10 PM
i might go with the S-Drives since lack of options...nothing against them, just wanted more options to check on...
as far as the rotas... i think +40 you might rub...might want to go with a tire that will give you better clearance than a 205/50... but if you do go 205/50/16 i hear the Conti DW and DWS are great!
Old May 23, 2012 | 08:17 PM
BlueBoogers's Avatar
215/45-17 all day. Ventus V12 Evos for $410 shipped with replacement certificates.
Old May 23, 2012 | 08:26 PM
215?
i want to keep the speedo and mpg as close to stock...
Old May 23, 2012 | 08:31 PM
Originally Posted by FIT-tles Worth
215?
2.5% off isn't horrible to me--worth it for the larger contact patch.
Old May 23, 2012 | 08:36 PM
im not too familiar with the percents on the tires... but which is almost stock? would 205 45 17 be closer than 195?
Old May 23, 2012 | 08:39 PM
Wanderer.'s Avatar
Originally Posted by fit-tles worth
215?
I want to keep the speedo and mpg as close to stock...
215/40/17 -
205/45/17 -
Both within 1%, for future reference you can check here:
http://www.miata.net/garage/tirecalc.html
Old May 23, 2012 | 08:41 PM
195 is the perfect width for 7j.
Just go with the S.Drives. I <3 mine.
Old May 23, 2012 | 08:49 PM
ThEvil0nE's Avatar
go with 195/45. s.drives are very nice daily tires. get some 5mm spacers for the rears too
Old May 23, 2012 | 08:55 PM
ThEvil0nE's Avatar
heads up tho... just be patient with the wheels. Work don't stock wheels with those kinds of offsets.
Old May 23, 2012 | 09:16 PM
bigpun54's Avatar
thanks for the advice ill check those conti's out...will a 205/45/16 give me good enough clearance than a 205/50/16 or not enough that it should matter... that's what im wondering the most....im kinda stuck with the wheels cuz i already bought them so theres nothing i can do about the whole offset thing...
Old May 23, 2012 | 09:17 PM
Wanderer.'s Avatar
FIT-tles Worth:
195/45/17 will be a slight stretch on 7" wheels.
205/45 or 215/40 will be a more traditional fitment and be square on the wheel.
I don't think you'll have to worry about rubbing with +47 offset no matter which you pick.
Old May 23, 2012 | 09:25 PM
195 S.Drives + 7j =
Old May 24, 2012 | 09:55 AM
Wanderer.'s Avatar
^I know that's what I figured too, i've had 195 on 7 in 15's (and 14's) before too and it was pretty square, idk why if I look at pictures online of 195/45/17 on 17x7 they all show a stretch.
Is it the tire type and sidewall height that make it look like that? Someone school me.
Old May 24, 2012 | 10:10 AM
hope not
Evasive told me end of June first of July
so 205/45/17 will be fine?
Old May 24, 2012 | 11:29 AM
ThEvil0nE's Avatar
depends on the tire itself. some tire bulge instead of giving that infamous stretch look. s.drives are one of those tires that gives you a nice stretch... tires like kumho on the other hand bulges.
here's an old pic of my fit with 195/45 s.drive on 17x7 +47 xd9 (note: rear has no 5mm spacers yet on this pic) I'm loving them cute stretch
Old May 24, 2012 | 11:38 AM
Wanderer.'s Avatar
Ah, thanks, I guess it has to do with the actual tread width on the tires, not all 195's are really 195mm, etc, and the sidewall design.
Old May 24, 2012 | 01:05 PM
i actually get a discount on Goodyear, yokohama, and Dunlop.
Yokohama s-Drive?
Goodyear GT?
Dunlop Direzza?
Thoughts on these in 205/45/17?
