Just ordered wheels...tires?
Old May 24, 2012 | 01:33 PM
SickFit's Avatar
Originally Posted by bigpun54
i'm on the same boat as u hommie....sorry for the thread hijack:d..... I'm gonna drop my fit on tein s techs and throwing some 16x7 40 offset rotas on but i'm wondering which tires size i should go with....i don't want them to rub so should i go 205/45/16 or 205/50/16.
195/50/16
Old May 24, 2012 | 02:16 PM
ThEvil0nE's Avatar
195/45 is the closest you get to stock rolling diameter and it is still within 7j specs. I can vouch s.drives... they're very nice tires and am confident with them even at higher speed 80+ even on occasional 100+
Old May 24, 2012 | 02:34 PM
ThEvil0nE's Avatar
^ my statement was for 17s
Old May 24, 2012 | 02:50 PM
FIT-tles Worth's Avatar
is 205/45/17 a bad option? i dont think it would rub with +47 offset. only slightly more rolling diameter
im just worried about this 'stretch' someone mentioned
Old May 24, 2012 | 02:59 PM
ThEvil0nE's Avatar
if you check... 195 is still within specs for a 7 wide wheels. anything that is within spec is safe... nothing to worry.
Old May 24, 2012 | 03:02 PM
JDMxGE8's Avatar
I had 215/40/17 Falken Ziex ZE-912s on my Work Emotion CR-Kai wheels (17x7 +42).
Old May 24, 2012 | 03:10 PM
ThEvil0nE's Avatar
those fancy color wheels again... ugh!!! me so likey _
Old May 24, 2012 | 03:23 PM
FitStir's Avatar
Don't worry about the slight stretch on the 195/45 S. Drives. They are good tires and plenty people have used them (on 17x7 wheels) with no problems at all (as mentioned they're within spec). You'll also have less rubbing if any, but that also depends on how low you drop it. The odometer will also be closer to stock w/ the 195's. Check out the GE8 Swifts spring thread & the No-Rubbing thread for more info on other peoples set-ups.
Personally whenever I get my special rims I'm looking at 17x7 +49(or +50), and I'm leaning towards the 205/45s myself with no more than an 1" drop for dd. I'd prefer the wider tire.
Oooh, those 215/40's on the CR-Kai's are nice!!!!!
Congrats on the Work XD9's OP.... Works ftw! Can't wait for my set.
Old May 24, 2012 | 03:25 PM
thanks my man! hope to post pics when i get the coil overs on with the wheels.
Old May 24, 2012 | 08:55 PM
bigpun54's Avatar
Originally Posted by SickFit
195/50/16
Thanks for the reply hommie...
Old May 24, 2012 | 10:45 PM
lowkeymods's Avatar
I bought S Drives due to lack of options and am very happy w/ them. I run a +40 and have no rubbing issue w/ daily driving.
Old May 25, 2012 | 10:44 AM
  #32
^ what are you lowered on? 17 x 7?
Old May 25, 2012 | 12:06 PM
  #33
lowkeymods's Avatar
Swift springs...yes 17x7 +40 offset w/ 195/45/17's
Old Jul 13, 2012 | 02:33 PM
  #34
cokeismetal's Avatar
id go with a 195/40/17. that guy mike410b's car isnt even low
Old Jul 13, 2012 | 02:34 PM
  #35
@lowkeymods how do you not poke in the front if you have a 40 offset?
Theos92vr4
Mar 12, 2012 01:32 AM
JDM-Taffeta-S
19
Oct 4, 2011 06:15 PM
AtticusFit
Jun 21, 2008 12:55 AM
MNfit
Mar 14, 2008 04:32 PM
tifosi360
Mar 19, 2006 09:36 PM
