Cabin air Filter - Car exhaust....?
Old Oct 16, 2012 | 03:27 AM
Fatbrando's Avatar
Hello all,
Hopefully not a stupid question, but I replaced my cabin air filter with an auto zone bought filter and now I seem to get a lot of the car and diesel exhaust smell from the vehicles in front of me. Is it me or was there a charcoal-like layer to the OEM filters...? Didn't seem as prevalent before.
Any help would be greatly appreciated.
Thanks,
FB
Old Oct 16, 2012 | 05:45 AM
Dwalbert320's Avatar
Bumb for an answer. Very curious!!!!
If nobody answers I will go pull my new one and see. Charcoal filters are grey/silver in appearance. Bosh and other companies make OEM style charcoal activated filters. If I recall correctly their useful lifespan is a matter of months...More expensive....I would be willing to invest in that!
Old Oct 16, 2012 | 08:18 AM
derek244's Avatar
Most true OEM (in Honda box) cabin filters for Honda do not have any charcoal in them actually. Some ads can be misleading. With that being said, I have seen some aftermarket filters of better quality than OEM. As far as the charcoal filtering diesel fumes, I guess it is possible if it takes some of the soot out. I have never had any luck personally, but then again I normally hurry up and switch to recirculate when I am behind them. I live in a somewhat rural area and always seem to be behind those $##@$% diesel redneck, jacked up, 10 inch exhaust dual exhaust stacks coming through the bed, rebel flag displaying, 40 inch monster mud tire having, james bond soot screen belching, 120 db blow off valve sounding, Cummins Power stickers having, mechanical abortions, driven by some 19 year old who claims to be "country".
Old Oct 16, 2012 | 01:27 PM
Subie's Avatar
FB, don't think the cabin filters have charcoal. They look like a regular furnace filter - for dust and pollen particles only. By the way here's another related thread you might be interested in: https://www.fitfreak.net/forums/fit-...placement.html
Derek, that's a pretty graphic "country" description you just did... Hey at least with the Fit you could probably peek through the undercarriage instead of driving blind... Oh yeah, no rifle rack?
Old Oct 16, 2012 | 01:48 PM
Red 05's Avatar
That perfectly describes the average Alabama southerner....
Old Oct 16, 2012 | 02:08 PM
Hello all,
Thanks,
FB
maybe you bumped your air cirulation lever to 'fresh.' move it back to the middle or recirculate when there is a stinky car in front?
Old Oct 16, 2012 | 03:04 PM
Subie's Avatar
Charcoal filter test
There's a big (cattle ranch/feeding station) area here by the freeway (I-5) in northern CA which would be the ultimate charcoal filter test I think. I don't think the Recirc setting will work either. You just hope you have tailwind as you approach and headwind as you pass by...
Old Oct 16, 2012 | 03:07 PM
damn, i can almost smell that just thinking about it. *barf*
Old Oct 16, 2012 | 04:30 PM
Subie's Avatar
Your nose will definitely let you know when you're getting close...
Old Oct 16, 2012 | 04:31 PM
Black3sr's Avatar
Cow shit is bearable. Try pigshit when they has just spread it. Whew!!!
I used to hate cleaning the pigpen. Now horse shit is a pleasant aroma.
My friendly chipmunk still shits in my cabin filter. I shake it out and spray with Frebreez(Sp). I must remember to switch to cabin air when parked.
Old Oct 16, 2012 | 04:33 PM
dang, black3sr...sounds like you are having a shitty day.
Old Oct 16, 2012 | 06:38 PM
Subie's Avatar
Maaaannnn, have to admit, can't top that! Won't touch it either... Name reminds me of Charlie Brown's side-kick.
Old Oct 17, 2012 | 11:02 AM
SilverbulletCSVT's Avatar
Stock filter is not charcoal activated. Maybe it was so clogged that it restricted air flow letting less smell creep inside. A new filter flows freely and so the outside stank comes inside more.
_
Old Oct 17, 2012 | 01:35 PM
Subie's Avatar
Arrow Alternate resource
Save some $$. Bought my cabin filter from these guys: 2008 Honda Fit Replacement Parts Cheap
Works fine...
Old Oct 17, 2012 | 03:07 PM
Fatbrando's Avatar
Thanks fellow Fitter's.
Much appreciated.
FB
Old Oct 17, 2012 | 05:19 PM
DaveFL's Avatar
I was under the dash, dropped the panels on both sides, on both there is filter material, laying on the plastic surface, held in place with cuts in the material. My question is are these the filters you are talking about? I have never seen a filter not cover a vent or tube forcing air though it, laying on a shelf of plastic with air passing near by doesn't filter anything, it just collects dust like any surface, probably less than my dash the way they are located under the dash.
Old Oct 17, 2012 | 05:25 PM
Subie's Avatar
The cabin filter is accessed through and located behind the glove box. Check your owner's manual. Not sure of what you're talking about.
Old Oct 17, 2012 | 09:15 PM
sound deadening material^
Facepalm*
Old Oct 17, 2012 | 09:35 PM
Wanderer.'s Avatar
I know this ranch you speak of, and no, recirc doesn't stop it. The east side of the Dumbarton Bridge smells almost as bad
Facepalm*
Yes, the filter is behind the glovebox, you have to drop the glovebox down and pull the filter out the little trapdoor. The door goes into the vent system behind the dash.
Old Jan 16, 2015 | 08:03 PM
Pucci's Avatar
Just bumping this old thread to note that a service guy at the local dealer where I bought my 2nd gen Fit claimed that the original factory-installed Fit filter has activated charcoal. That sounded like malarkey because I did not remember seeing what looked like an activate charcoal filter when I had the original filter changed.
