Odd sound (thoughts?)
Old Oct 19, 2012 | 02:06 PM
hogwylde's Avatar
Over the past couple of days I've noticed an odd sound on my '09 Sport albeit it doesn't always do it. After driving and putting it into Park, I hear a quick whirring noise (like the old power antennas) that lasts for about a second or two. Has anybody else ever experienced this?
Old Oct 19, 2012 | 02:48 PM
malraux's Avatar
Milage? Changed the transmission fluid recently? Checked its level?
If I'm inside my garage with the windows on the car rolled down, I can hear various sounds from the transmission when I shift between the various settings (P, R, N D). It does sound kinda like a pump and relay opening.
Old Oct 19, 2012 | 03:09 PM
hogwylde's Avatar
It has 22,xxx on the odometer and the transmission fluid has never been changed. I do admit that I didn't check the level and will do that in a few.
Old Oct 19, 2012 | 03:34 PM
have you had the muffler bearing checked? might be time to get a new one.
Old Oct 19, 2012 | 03:45 PM
malraux's Avatar
Also, if the sound is reliably reproducible, it should be pretty easy to locate with two people.
Old Oct 19, 2012 | 04:40 PM
hogwylde's Avatar
The sound does seem to be coming from the rear. I'll start there.
Old Oct 19, 2012 | 04:45 PM
hogwylde's Avatar
I just checked the level and it's right on the mark.
Old Oct 19, 2012 | 04:48 PM
hogwylde's Avatar
The muffler bearings seem to be ok. Could it be the turbo encabulator?
Old Oct 19, 2012 | 05:16 PM
DaveFL's Avatar
While you are eliminating the easy things, check to see if it is the fan cooling engine, even if it is in the front, I added a trailer hitch and just the ball on the tube made a lot of noise and it was impossible to say where is was coming from. Duct tape around tube, stopped all the noise.
Old Oct 19, 2012 | 05:48 PM
hogwylde's Avatar
Crazy part is it sounds like it is coming from the rear. The car is stock and nothing is back there that I can think of that would make a noise like that.
Old Oct 19, 2012 | 05:52 PM
malraux's Avatar
Do your doors unlock when you put it into park?
Old Oct 19, 2012 | 06:50 PM
x_25's Avatar
I get the same thing when I turn off my 2011 Fit 5MT. It's like a Weeerp! sound from the back somewhere. Almost sounds like a vacuum type thing. I am inclined to think it has something to do with the fuel system evaporative emissions stuff.
Old Oct 19, 2012 | 07:11 PM
SieGunso's Avatar
rear wipers.
Old Oct 19, 2012 | 07:19 PM
hogwylde's Avatar
I didn't think about that! They do! I'll change the programming and see what is does. Thanks!
Old Oct 19, 2012 | 07:22 PM
hogwylde's Avatar
Weeerp is the perfect way to describe the sound! I'm assuming you just live with it? The only thing that gets me to think something is askew is because it never did it until a couple of days ago.
I'm going to try changing when the doors lock/unlock as previously mentioned to see what that does.
hogwylde's Avatar
Originally Posted by SieGunso
rear wipers.
Negative. I never use it.
Old Oct 19, 2012 | 07:28 PM
x_25's Avatar
Well then I can assure you that if you ignore it for 20k miles nothing will go wrong.
Mine has been doing it, as far as I can tell, since almost when it was new. It only does it sometimes and I thought it had something to do with turning the car off, but apparently not! Then again, having a manual, mine unlocks the doors when the key is turned to the accessory position, not when shifted into park (which, I happen to be lacking). Let me know if it is the door locks or not. I will continue to ignore it for now.
Old Oct 19, 2012 | 07:41 PM
Dwalbert320's Avatar
Weeerp is the perfect sound to describe it. Mine is doing it too and it is going to Honda on Monday. It happens when you put it in park. The door unlock....weeerp!
I'll try a little can of pneumatic aerosol to see if I can make it go away in the meantime.
Old Oct 19, 2012 | 07:59 PM
hogwylde's Avatar
Mine actually seems to happen in the milliseconds between going into park and the doors unlocking. But from the rear! Is your car going in on Monday for this problem or for something else and you'll mention it?
Old Oct 19, 2012 | 08:03 PM
exactly for that
