New Honda Fit Sport - chaning tires/wheels dealer wants $280
Old Oct 31, 2012 | 07:05 AM
ed_in_texas's Avatar
Alignment has always been a rear wheel drive thing.
The front wheel drive cars I have owned don't seem to lose it. Ever.
Old Oct 31, 2012 | 03:04 PM
Fit29er's Avatar
Originally Posted by specboy
Agreed. Doughnuts never hurt at a dealer. My wife made a bunch of baked goods for a bake sale and I took the rest to the dealer when I needed some maintenence done. Guys (and gals) there loved it and the work was done super-quick.
Also, OP, if you are having an alignment done, that's where the real cost is coming in. Reprogramming the TPMS shouldn't be more than about $100 as others have said.
~SB
It makes sense now. I never bothered changing wheels/tires in my Subaru so when I head $280 I was a little bit upset. Hopefully I will be able sell stock wheels.
Old Oct 31, 2012 | 05:50 PM
kgb4187's Avatar
There's absolutely no reason to have an alignment done when changing tires/rims under normal circumstances. I thought you meant having the wheels balanced.
Old Oct 31, 2012 | 09:35 PM
specboy's Avatar
That's what I thought at first until I read that they bought the entire package from Tirerack (or DTD, can't remember). both do the full mounting and balancing for you so all that's left is mounting them on the car and programming the TPMS.
~SB
Old Oct 31, 2012 | 09:41 PM
Fit29er's Avatar
~SB
So it should cost no more $150 without alignment. Before I traded my Subaru in for a Fit, I constantly had to align wheels when rotating tires.
Old Nov 1, 2012 | 12:23 AM
kgb4187's Avatar
I mean no disrespect when I say this... but you're a sucker. Who told you that? You get an alignment after suspension work, when your tires wear unevenly or when the car tracks to the side. The work should cost $50-60 at most. Don't have the dealer do it. Take it to a dedicated tire shop. Discount Tire, Custom Wheels, Truck & Car Rims | Discount Tire might be your best bet, its the only place I go to.
Old Nov 1, 2012 | 12:31 AM
Fit29er's Avatar
None taken. I will have to go Mavis Discount Tire. I asked my wife again and she said the dealer said (installation, rotating and TMPS programming for $280). They said nothing about the alignment. That makes a complete ripoff then.
p.s. I am quite handy built bicycles, computers, minor plumbing, painting etc. but cars are a different story.
Old Nov 1, 2012 | 01:13 AM
Please consider this path.
Alloy wheels require different lug nuts. The seating surface is is a flat 60 chamfer vs a section of a donut/toroid.
When you receive the wheels remove the old wheels and put on the new wheels making sure the correct lug nuts are tightened to the value in the owners manual. Save one set of the old lug nut for use with the spare tire. If you have to buy a socket and breaker bar to work with the new lug nuts, do that and keep them in the car.
Drive to the service area of the dealer with the car, new tires already installed. The only work you are asking them to do is reprogram the tpms sensors. They don't have to touch a wrench. They do have to drive the car around.
Offer them $80 as all you are looking for is the convenience on not having to look at the low tire pressure light sending bad information.
Old Nov 1, 2012 | 01:20 AM
Goobers's Avatar
I think you meant aftermarket wheels. The Sport has alloy wheels with the ball seat lug nuts (what you were calling "donut").
Old Nov 1, 2012 | 02:14 AM
Thank you.
Old Nov 1, 2012 | 04:16 AM
Fit29er's Avatar
Go it. The dealer is "cheap" and they charge a minimum of $105 per hour even if it takes 20 minutes.
Btw, I got Rial Murago wheels.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old Nov 1, 2012 | 06:48 AM
  #32
Nice split spoke wheels. Should work well on a Fit!
Old Nov 1, 2012 | 09:10 AM
  #33
Brain Champagne's Avatar
Rotation? If they're taking the wheels off the car to install new tires or installing the old tires on new rims they shouldn't also be charging for rotation. There's no extra time involved.
Old Nov 1, 2012 | 03:53 PM
  #34
kgb4187's Avatar
I think that's how they write up a wheel swap. Same labor as a rotation, and swap probably isn't listed in the labor rate system.
Old Nov 1, 2012 | 04:02 PM
  #35
Fit29er's Avatar
Guys,
I called Tarrytown Honda. They said $105 for programming TPMS and $52 for mounting the wheels.
Old Nov 1, 2012 | 05:41 PM
  #36
kgb4187's Avatar
And what did tire shops quote you?
Old Nov 1, 2012 | 08:09 PM
  #37
Fit29er's Avatar
Unreachable because there is no electricity.
Old Nov 1, 2012 | 08:41 PM
  #38
kgb4187's Avatar
Maybe wait a few weeks... Are you in a rush to change the wheels out?
Old Nov 1, 2012 | 10:42 PM
  #39
Fit29er's Avatar
I do not want to have my stock wheels stolen since I did not put wheel locks.
Old Dec 2, 2012 | 12:12 PM
  #40
dasautoatheart's Avatar
What?
Originally Posted by evil_s10
So if the above is true, your going to need the wheels and tires (which im assuming are coming mounted/balanced from tire rack) installed onto the vehicle. A 4 wheel alignment and the tpms reprogrammed. To me the 280 price sounds about right as a 4 wheel alignment is normally ~139, say 100 for the tpms reprogram and 40 for the installation of the wheels.
If he is just mounting new wheels, why does he need an alignment?
