Specs for GE Base Steel wheels
Old Dec 13, 2012 | 03:17 PM
salogni63's Avatar
Sorry if this has been posted somewhere already - I haven't been able to find it on this forum or any others I've browsed.
Does anyone know the offset and hub bore specs for the base steel wheels that come on the Base 2nd Gen (GE) Fit?
If not, anyone know where I could get such information?
Thanks!
Old Dec 17, 2012 | 06:13 PM
Mini_Odyssey's Avatar
Thanks!
Size is 15 x 5.5J, PCD 4x100, hub Bore should be 56mm, Offset i think was +45
Old Dec 17, 2012 | 06:35 PM
salogni63's Avatar
Thanks! I appreciate the response.
If you don't mind my further verification, where'd you hear this info? I'm curious because I can't seem to find a really solid, definitive answer on this question. All of my forum searching has turned up variations of "someone told me..." or "I think..." or "it should be..."
Everyone seems to think, similarly, the hub bore is 56.1mm, as you said.
Re: offset, I've heard 45, 55, 53, 50.
Old Dec 17, 2012 | 07:04 PM
You're right its +55 on the offset, +45 was for the Insight models. Fail for me.
So to recap:
Size: 15 x 5.5J
Offset: +55
PCD: 4x100
Bore: 56.1
Weight: Approx ~17.3lbs
Old Dec 17, 2012 | 07:46 PM
salogni63's Avatar
So to recap:
Size: 15 x 5.5J
Offset: +55
PCD: 4x100
Bore: 56.1
Please, I appreciate the input!
Ever heard of anyone having problems taking the stock steel wheels from the GE and putting them on the GD? Success stories are also welcome
Old Dec 18, 2012 | 09:54 AM
I dont see why not, i seen GE guys running GD wheels all the time as well.
Old Dec 18, 2012 | 12:08 PM
salogni63's Avatar
Hey Mini_Odyssey,
I found one (only one) 2010 steel wheel very close to me. Do you know if the 2010 and 2009 steel wheels are identical?
If they are, my thought is I could ask them to slap it on for me and see how it fits at least.
Old Dec 18, 2012 | 12:59 PM
Hey Mini_Odyssey,
As far as i know, the steel wheels are unchanged from 2009-2013 on base models. The changes i think were the aluminum versions went from 16x6 to 16x6.5
richard612
Feb 15, 2011 05:44 PM
Bounty Hunter
Sep 18, 2007 12:33 AM
j5ive
Car Shows, Events, and Racing
Apr 13, 2007 08:10 PM
Gabes Dad
Jun 23, 2006 03:22 PM
Bill L
May 2, 2006 05:21 PM
