drive belt/tensioner pully
Old Dec 14, 2022 | 12:46 PM
Frenzal's Avatar
Originally Posted by classicsincanada@shaw.ca
By changing the tensioner and belt together I noticed the engine noise was less and my power steering was a bit lighter.
As the power steering on the Fit is electric, I doubt the tensionner has anything to do with the lighter power steering...
Old Dec 30, 2022 | 03:31 AM
maikleoliver's Avatar
Originally Posted by rossftn
Hi,
I have a 2009 Fit Sport with 106K miles on it, and have never had a single problem with it (at least until now ). I keep up with all of the maintenance myself, and this site has helped me out quite a bit - especially when I changed the brake fluid a few months ago.
Nox Vidmate VLC
I decided to change the serpentine belt a couple of weeks ago. It didn't appear cracked or anything, but at over 100K miles I figured that it would be a good idea to change it anyways. It was a MAJOR pain in the rear, but I managed to pull it off on my own.
The problem is that the tensioner pulley almost immediately started making a dull, whiny noise after I changed the belt. Sometimes it goes away for a while, but it is pretty consistent. The pulley seems to have a tiny bit of wobble in it at idle (its so small that I can't help but to think it may not be an issue). To be on the safe side, I ordered a replacement pulley and will install it after it comes in the mail.
I was just wondering if anybody else has had a problem with their tensioner pulley. I searched the forums and there isn't much on it (or drive belts at all, for that matter). It just makes me a lot more comfortable if I see a bunch of people with the same problem. Also, does anybody know why changing the belt could have damaged the pulley? I checked the tension of the belt and it is perfect.
From past experiences the factory $26 Japanese Mitsuboshi belt has better rubber quality then the American made Dayco or Goodyear ones.
Old Dec 31, 2022 | 09:58 AM
Mister Coffee's Avatar
For those of you who are working at my relatively low mechanical level, we are talking about two discrete parts: the tensioner and the tensioner pulley. I had to look it up.
Old Dec 31, 2022 | 11:50 AM
Frenzal's Avatar
You can normally buy the tensioner as an assembly, with the pulley. You can also buy the pulley separately. That was the case for the one on my Accord, at least. Should be the same for the Fit.
Old Jan 14, 2024 | 11:40 PM
Honda2009Mt's Avatar
Replaced belt and car dies
Always put a new quality tensioner pulley on when you change the belt. Its not worth the headaches.
hey so I’m about to replace the tensioner now since there’s a squeal noise from the tensioner.
will this pulley really turn off the car, I haven’t removed the tire yet to see more.
grommet
Apr 27, 2026 09:57 PM
jilm
Apr 13, 2016 06:22 PM
lightyear22
Oct 1, 2014 07:47 AM
Marrk
Oct 23, 2009 07:32 PM
jim beam
May 4, 2005 11:16 AM
