Too much coolant?
Old Mar 16, 2013 | 11:50 AM
Crisu's Avatar
Too much coolant?
I have a 2012 Fit. I took it in for an oil change yesterday, and when I got the car back, I noticed the mechanic also checked and gave me extra brake fluid and water in my coolant reservoir while he was at it.
He didn't see the MAX line halfway down the reservoir tank and filled it far past that.
If I recall correctly, this is a problem that usually fixes itself. If there is excess coolant, it will just overflow out of a spout (harmless to the car). I can't see where that happens on my Fit's reservoir tank. Can someone help point me to where it is (for peace of mind, really)? Or am I better of siphoning the extra coolant out?
Picture of reservoir - http://puu.sh/2iGwN
Picture of engine in general - http://puu.sh/2iGwq
Thanks!
Old Mar 16, 2013 | 01:56 PM
JazzITup85's Avatar
You should be fine, car will not be hurt with extra coolant. If it really a problem to you, just take a 10mm & take off the tank & drain overflow coolant.
Old Mar 16, 2013 | 02:38 PM
Texas Coyote's Avatar
If the engine gets hot enough that it bleeds off coolant into the reserve tank it will bleed any access in the tank out the vent hose onto the ground.
Old Mar 16, 2013 | 05:12 PM
raytseng's Avatar
Also, You may also have a couple air bubbles hiding here and there, so the coolant level will resettle lower in a few days of driving in itself too...Wait until then before doing anything
doctor J
Jan 23, 2019 03:02 PM
wzard999
Oct 15, 2013 10:48 PM
cakacon
Oct 15, 2011 08:35 PM
gladel
Jun 19, 2009 07:21 PM
Fijoy George
Aug 10, 2005 12:20 PM
