USB stick format
Old Apr 3, 2013 | 04:26 PM
Carmen Sandiego's Avatar
USB stick format
Anyone know what file format the USB interface should be on this car?
I'm using FAT32, but for some reason every other file is unplayable, as if there's two versions of every song.
I have 11 songs on the USB, but it's showing as 22, and half are unplayable. I searched, but it seemed to be FAT32 consensus, so I'm not sure what the deal is. Thanks.
Old Apr 3, 2013 | 04:33 PM
StinklePink's Avatar
Depends on the size of the USB drive. Bigger ones need some special handling.
Old Apr 3, 2013 | 04:34 PM
It's a 32GB Kingston Data Traveler 100G2. Thanks for any advice on it.
Old Apr 3, 2013 | 04:42 PM
Originally Posted by cjecpa
Is it dented in or scratches? I usually end up parking a couple miles away and still get back to my car and find someone parking right on top of it. It sucks especially with a new car or any car when you take care of it.
People are just jerks. It's scratches, but you know on a black Fit, they show up white and it's horrible. Weird, I think I made two threads too close together as I only see one now.
Anyway, I decided to just get an estimate and not drive myself crazy over it. It's not worth the stress.
Old Apr 3, 2013 | 06:27 PM
Codi's Avatar
FAT32 should be working fine. Biggest issue I've run into personally is audio formats. I think I have a 32g as well.
Old Apr 3, 2013 | 06:43 PM
cjecpa's Avatar
Should be easier to get repaired good luck.
Old Apr 3, 2013 | 06:48 PM
DaveFL's Avatar
WMA file format works for me, but I have a smaller stick.
Old Apr 4, 2013 | 08:45 AM
E J's Avatar
E J
Did you copy the files to the USB using a Mac?
If so, FAT systems will show the hidden OSX files.
If you put the USB stick in a PC, you'd see files like:
._Song1
._Song2
._etc
Song1
Song2
etc
Old Apr 4, 2013 | 08:58 AM
Schoat333's Avatar
._Song1
._Song2
._etc
Song1
Song2
etc
Weird, I use a Mac, and don't have any problems with unplayable files.
Old Apr 4, 2013 | 09:28 AM
The thread that I went to when I was having this problem: https://www.fitfreak.net/forums/2nd-...h-drive-4.html
The steps I used are in my posts. I had a larger drive so not sure it was the same issue you are seeing. I think issue is formatting of a 64GB drive.
Old Apr 4, 2013 | 11:52 AM
E J's Avatar
E J
Not sure if that's the cause here, I've seen it with people who move other files from Macs to PCs via USB sticks so I thought I'd put it out there as a possibility.
Old Apr 4, 2013 | 01:21 PM
._Song1
._Song2
._etc
Song1
Song2
etc
Yes, actually, I did copy the files using a Mac. I'll investigate this a bit more. Thanks for the input.
Bassguitarist1985
15
Sep 10, 2014 05:51 PM
rr1024
Apr 2, 2014 12:41 PM
Mister_ELK
Jan 2, 2014 10:30 AM
OliviaNewtonJohn
Jul 11, 2012 08:05 PM
dontaskbrad
Jun 25, 2010 11:29 AM
