Battery problem Fit Sport
Old May 4, 2013 | 10:30 PM
madd river's Avatar
Hi members. I hope i am posting this question correctly in the right place. My problem is my battery on my new Fit Sport needed to be recharged ( Lights left on overnight) and is working fine now. The problem is the red circle indicator is showing it needs water but all the six cells have been filled. I live in the tropics and I guess the sun takes its toll. Help please
Old May 4, 2013 | 10:33 PM
CasualFitOwner's Avatar
Drive around on highway for 30min to 1hour to see if that will sufficiently charge the battery.
Old May 4, 2013 | 10:48 PM
Steve244's Avatar
edit: the outer ring on the indicator is blue and the inner dot red when charged. The outer ring is red when the water level is low. A discharged condition the outer ring is clear, the inner dot is red. (at least according to the OE battery label on mine; confusing huh?).
It might take a couple days normal use for it to go "blue" (fully charge) but it will have plenty of charge to start in the meantime. At least that was my experience after someone left the lights on in mine. Don't worry; they've been banished from the Fit.
Old May 5, 2013 | 01:11 AM
13fit's Avatar
I highly suggest hooking it to a battery tender overnight. Go borrow one from any motorcycle owner, at least any REAL cycle owner.
Old May 7, 2013 | 04:27 PM
madd river's Avatar
Hey guys many thanks for your answers.
Old May 7, 2013 | 04:29 PM
madd river's Avatar
Hey Steve thanks for the diagram and breaking it down for me. The battery circle has not turned blue yet and if i understood the diagram the clear circle means it is not charged which confuses me cause it starts quickly and all accesories come on quick.
Old May 7, 2013 | 04:38 PM
madd- the car will still start with less than full charge. you will want to drive on the hwy for 30min to 1hr per wat casualfitowner posted. that's sound advice for quick charge.
then, if you have a bettery tender (charger that floats at full, not a trickle charger), use that to charge the rest, or drive hwy the following few days and dont do any short trips under 5miles.
Old May 7, 2013 | 08:14 PM
rcase13's Avatar
I don't have a battery tender for my motorcycle. It's not needed! I ride it year round!
Plus it's a Honda. Starts every time!
Old May 10, 2013 | 03:48 PM
madd river's Avatar
Kenchan, thanks for your feedback. i do have a battery charger.
TommyMadison
May 4, 2017 11:25 PM
mexfreak
Jun 14, 2015 10:16 AM
Marrk
May 23, 2015 01:09 AM
john21031
Nov 21, 2013 12:03 AM
vwli
Feb 15, 2009 09:53 AM
