One tire slowly leaks air (doesn't go flat). Thinking its a bad valve...
Old May 6, 2013 | 12:47 PM
workin9classhero's Avatar
Can I get this issue resolved without it messing up the TPMS?
Old May 6, 2013 | 12:53 PM
Wafulz's Avatar
find were its leaking with soap and water
then fix it at a shop
Old May 6, 2013 | 01:16 PM
Steve244's Avatar
If your soapy-water experiment points to the valve, then yes, you can unscrew the valve-core and replace it without affecting the TPMS.
You'll need something like this. You'll need something like this.
Check a bike shop or your friend's 10 speed.
And this.
or just this. or just this.
Best jack it up first as when you remove the valve-core the air will exit PDF.
And have an air-pump handy.
stupid vb software, I really only put the links in once.
Old May 6, 2013 | 01:25 PM
Can you tell me about the soap and water method?
Old May 6, 2013 | 01:32 PM
Wafulz's Avatar
a small spray bottle mix with water and soap or a wet sponge with soap
will start bubbling if theirs a leak
Old May 6, 2013 | 01:46 PM
i would take it to discounttires (americas tires) to get that fixed. they usually have non-touch mounters so they wont scuff your wheel if they determine it's a bad bead.
Old May 6, 2013 | 04:22 PM
xxryu139xx's Avatar
jack it up and rotate the wheel. inspect for nails etc. spray the whole wheel with soap and water and look for bubbling.
or goto local tire shop and have them look at it. wont cost more than 15 bucks to get it plugged up too.
Old May 6, 2013 | 06:17 PM
annunC8's Avatar
This may not be your problem, but something to consider.
I had OEM Bridgestone tires on my Fit, bumped curbs with them on two separate occasions developing a really slow leak both times. I thought maybe (both times) I got an object in my tire, but when having the tire(s) checked found bumping the curbs broke the "tire seal" (Honda tech's term, not mine) causing a slight leak to the tire.
I didn't know this was possible... but both times the Honda mech remounted the tire and the leak was fixed. He did check for puncture leaks before remounting... obviously found none. No problems involving the TPMS here.
He said the Bridgestone and Dunlop OEMs were famous for these types of problems.
If you have a puncture and the tire can be repaired and you have someone do the work, make them aware of the TPMS and hold them accountable before the repair. If they refuse to be held accountable for the TPMS then run away... FAST! Go to someone who will guarantee TPMS safety.
Chazzlee
Jan 22, 2015 09:37 PM
fitowner10
Sep 11, 2014 02:15 PM
cjecpa
Apr 12, 2013 12:04 PM
ken_vs_ryu
May 12, 2009 09:56 PM
