Fuse replacement tip
Old Sep 8, 2013 | 02:41 PM
barrythomas's Avatar
fuse panel
can someone tell me if fuse should be in all the live slots or is it ok if some slots are empty? I drive a 2009 FIT. The only thing not working is my wing mirror adjusters
Old Sep 8, 2013 | 10:38 PM
Goobers's Avatar
Chances are good... if there's a live slot, there's a reason why its live. In other words, it most likely is already wired and has a fuse for something around the car.
If you're mirror isn't working, a fuse is blown.
Old Sep 10, 2013 | 12:00 AM
kk thanks. I inserted the fuse but that was not the issue. The wire that connected the mirror adjuster to somewhere (probably the fuse panel or battery) was disconnected. I plugged it in and am good to go now.
Old Sep 10, 2013 | 12:59 AM
Goobers's Avatar
Did you buy the car used? Sometimes, a previous owner will do something for some reason or another. They may or may not remember it... or even care.
No fuse and unplugged wire sounds like a previous owner did it. One possible excuse is that they had their mirrors set the way they liked it and didn't want anyone else messing with the angles through the controls.
Old Jun 7, 2014 | 08:35 PM
gkitf16's Avatar
My favorite tool of choice for getting the little bugger's out is a hemostat clamp. I dropped one once inside the kick panel while using the puller....never again!
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
fad3r
Jan 27, 2013 04:04 PM
TWGE08
Jun 10, 2009 07:54 PM
W
Sep 29, 2005 12:30 PM
