Fuel Burn Issues 09 Honda Fit Base Model w/ Manual Trans.
Old Jun 23, 2013 | 03:29 PM
bl00dtx's Avatar
Hello guys, and maybe gals...
I'm havin' an issue with my 09 FIT.. I recently hit 91000 miles on the odometer, the only maintenance I've done was oil changes, breaks, and few weeks ago replaced the spark plugs. Anyway the car used to make about 300 to 330 miles with a full gas tank, and lately its only going for like 230-250 and I have to refuel again... It's weird, why would she burn more??? I don't get it, and I don't drive it all crazy, just nice and easy... Always with the AC on... so what could the deal be ??? Any1 got any ideas???
Old Jun 23, 2013 | 05:44 PM
Steve244's Avatar
getting close to time for valve adjustment. Couldn't hurt.
Otherwise it's probably just a change in driving patterns.
Old Jun 24, 2013 | 03:58 AM
loudbang's Avatar
What he said it's past due. ^^^^
Old Jun 24, 2013 | 08:24 PM
bl00dtx's Avatar
ouch ! so how much is that, and at usually how many miles ur supose to do it ??
Old Jun 24, 2013 | 08:26 PM
Steve244's Avatar
around 100K. Some will say do it every 30K but not Honda...
It's around $300.00 if you have Honda do it. Maybe more if you DIY without the proper tools/experience.
Old Jun 24, 2013 | 10:36 PM
13fit's Avatar
fuel filter, air filter, and check the battery ground for corrosion and damage
Old Jun 25, 2013 | 08:34 AM
Brain Champagne's Avatar
If it started when you replaced the spark plugs, maybe the gap was wrong?
Old Jun 25, 2013 | 11:15 AM
Santiad's Avatar
fuel filter
Anyone have a DIY for the fuel filter?
I've read the SM but I'm sure there are kinks not mentioned there.
I also agree with the previous comment about valve adjustments....if you dont feel comfortable take it to Honda (they charged me $200)
I did it myself but I didnt have angled feelers and the end result was ROUGH....then I gave my cousin the job of torquing the valve cover.....and he broke a bolt head, leading to me having it tapped. I asked if he torqued it to 17lbs, then I checked the socket and it was still at 75lb!!
Old Jun 25, 2013 | 11:57 AM
Steve244's Avatar
Unless it throws a code for low fuel pressure, I'd leave the filter alone. It's not a maintenance item.
jfw432
Jan 23, 2019 09:19 PM
boltaction
Aug 12, 2018 10:15 AM
gwai-lo
Jul 26, 2014 09:18 PM
Santiad
Mar 6, 2014 04:21 AM
SadaYama
May 4, 2005 11:16 AM
