P0111 IAT sensor performance.
Old Aug 27, 2013 | 04:20 AM
loudbang's Avatar
Old Aug 27, 2013 | 06:10 PM
Steve244's Avatar
Thanks for posting the links you referenced. Did you watch them?
MAF Mystery Part 3 of 4 What does it take to foul a MAF is what you referred to, I think. At 0:31minutes, after submerging in oil "voltage readings were a little awkward" but returned to normal after several cycles (not defined) with no further dunkings.
Their conclusion offered in Part 1 Intro and Test Results: "we have discovered no oil will come off of a filter under any normal operating conditions." (6:52). They did not describe what would happen if excessive oil were applied. They attempt to simulate normal operating conditions in part 2 of 4, but lack in methodology. Their measurements were on a single vehicle (chevy silverado) measuring airspeed anywhere between 1MPH and 12MPH (at an arbitrary location on the filter), and simulating this in a lab measuring cubic feet per minute (CFM). No attempt was made to correlate the two.
The videos were well produced. They did no field testing. They show coating with K&N oil does corrupt MAF readings but these return to normal after removing the source of the oil.
If it were me, I would schedule a test where several different types of cars have oil over-applied to the filters. Drive normally for 2 weeks. Test the MAFs for function and contamination. Repeat as necessary to quantify over-oiling.
Notes
Old Aug 28, 2013 | 03:29 AM
loudbang's Avatar
But we are not you thank god. But feel free to do it on your own. I knew even before I posted you would find something, anything, to disagree with.
Old Aug 28, 2013 | 08:09 AM
Steve244's Avatar
I'm disagreeing with you.
It's on here in one of the threads. MAF sensor completely SUBMERGED in oil and placed back on the vehicle and started and guess what NO PROBLEM.
Not only did it have problems, it was never "placed back on the vehicle and started."
Jutboy
15
May 16, 2024 07:11 AM
rwjd
Apr 12, 2024 11:54 AM
pkunk
Mar 11, 2019 03:32 AM
bobblebob13
Jun 19, 2013 01:34 AM
Hirvi
Nov 25, 2011 11:11 PM
