Check my winter tire selection please
Old Sep 20, 2013 | 07:01 PM
terahz's Avatar
4x100, at least 56.1mm hub bore: exactly if you want hubcentric, greater if it's not that important to you. I've run non hubcentric steelies in some pretty rough conditions and they were fine, so take that for what you will. Offset is not that important as most steel wheels have high or close to factory offsets anyway. At least 14" wheels to clear the brake calipers.
Good luck with your search
Thanks very much. I guess worst case I can get these with free shipping (love prime) :
Unique Wheel 83 Black Wheel (14x5.5"/4x100mm) : Amazon.com : Automotive Unique Wheel 83 Black Wheel (14x5.5"/4x100mm) : Amazon.com : Automotive
, they should work, right? Should I contact unique wheel to ask about the bore or is there such a thing as universal?
Thanks again.
Old Sep 22, 2013 | 11:17 AM
mahout's Avatar
Originally Posted by terahz
Thanks very much. I guess worst case I can get these with free shipping (love prime) : Unique Wheel 83 Black Wheel (14x5.5"/4x100mm) : Amazon.com : Automotive, they should work, right? Should I contact unique wheel to ask about the bore or is there such a thing as universal?
Thanks again.
Let me add that we have dozens of Hondas here and hundreds more other brands who have never used hubcentric wheels. Regardless what is said the wheels are oriented and fastened by the lugnuts.
There are lots of Honda, Mazda, and Toyota 4x100 wheels out there in scrapyards at $10-15 a wheel that will meet your needs for snow tires.
Offset is generally 45 to 55 mm which work fine. The 45 mm is of course best because it gives a little wider track thus camber that helps in snow. If you want you can buy 1/4" spacers to widen track by 12mm (55mm then become 49mm offset per wheel). The main thing getting wheels on craigslist or ebay is ensuring the wheels clear the brake calipers. Its not automatic but it has happened to buyers. And check the used wheels foir straightness by spinning against a marker front and rear of each rim. (thats why local junkyards are better than craigslist or ebay, you inspect before you buy.)
BTW when you get snow tires a tad less narrow section and tad bigger diameter are advantages in snow but nothing beats the tread design. And if you find a wheel, unlikely but, with hub bore too small those spacers will eliminate the problem by setting the bore outside the hub.
good luck.
Old Sep 22, 2013 | 02:37 PM
Wanderer.'s Avatar
Thanks very much. I guess worst case I can get these with free shipping (love prime) : Video Link: http://www.amazon.com/Unique-Wheel-Black-14x5-5-4x100mm/dp/B003OBZ7P0, they should work, right? Should I contact unique wheel to ask about the bore or is there such a thing as universal? Thanks again.
Those are fine, those are the exact wheels I've used before on another car. They are not hub centric. Make sure they clear your calipers, but I think it will be fine.
They are fairly strong, I've put them on a racetrack and had a few offs with them with 50 series sidewalls and they didn't bend at all.
Fit2009BaseAT
Nov 6, 2014 11:30 PM
medbill
Oct 27, 2014 10:46 AM
Stovepipe
Nov 27, 2012 10:37 PM
britdevine
Aug 21, 2011 09:56 PM
hspatz
Mar 11, 2010 06:48 PM
