09 fit need to locate AC relay
Old Aug 18, 2013 | 03:45 PM
buickford's Avatar
Question 09 fit need to locate AC relay
I have an 09 Fit and the AC stopped working. The fuses look good. I want to check the relay for the AC compressor but the fuse panel does not say which relay is which.
Does anyone have a diagram showing what each relay i for?
Old Aug 18, 2013 | 04:54 PM
Dean's Avatar
Got this link on my initial search:
https://www.fitfreak.net/forums/fit-...tch-relay.html
Hope it helps.
Old Aug 18, 2013 | 07:45 PM
connor55's Avatar
The relay is located in a little black box behind/under the driers side headlight. It should just pop open without tools.
Old Jun 18, 2017 | 05:27 PM
billtmore's Avatar
Conner55 thanks for posting where the relay box is...tucked behind that headlight ...no clue as to where it is in the manuals or really online
Old Jun 18, 2017 | 08:18 PM
hydrocynus's Avatar
forcing AC compressor to engage Honda FIT Sport '09
Was running low on refrigerant and added some. Car cooled well for a week. I then went out of town for a week and the compressor does not kick. I cannot check the pressure on the low pressure port then. Pressure right now reads in the red but that is normal when the compressor does not kick.
which one of the three relays is the one controlling the clutch and how to short so that the compressor engages?
thanks.
Old Jun 18, 2017 | 08:31 PM
billtmore's Avatar
what i would do is locate the box. The relay that runs length wise is the AC clutch (the other 2 that are next to each other run in the other direction. another way to explain is it is the lone relay that is towards the fender. I would swap out one from the other 2 as all 3 are identical. see if your compressor kicks on like mine did. It might!!! or not one way to find out. let me know
Bill
Old Jun 14, 2018 | 09:02 PM
Peter Scott's Avatar
Thabks to this forum, ive found where the relay is located... can I ask how anyone was able to remove them to test? I can barely get my hand down there to try. Do you have to remoce the battery?
Bill
Old Jun 14, 2018 | 10:47 PM
billtmore's Avatar
Peter if you are having AC problems this might be your answer. all the info you need is online you just have to research it and figure it out removing the battery is easy. spend the time to figure it out. I knew which was the compressor relay and swapped it out with one of the others and the AC kicked on. THAT is how I knew I had a bad power relay. power relay can be bought on amazon for 20 dollars
Old Jun 14, 2018 | 11:07 PM
billtmore's Avatar
this is where the box is on 2nd gen fit
Panthese
33
Aug 18, 2020 12:08 PM
gahris
May 14, 2017 04:51 PM
jgold@desktoppub.com
Jul 20, 2016 01:46 AM
Sjensen9
Aug 8, 2015 11:13 AM
k-alt
Jul 9, 2012 11:01 AM
