poor safety ratings on fit?
Old Jan 25, 2014 | 03:58 PM
  #61
Steve244's Avatar
The IIHS found fault with the Fit's integrity in the test in two areas:
  • The seatbelt didn't properly restrain the dummy and allowed him to do a face-plant to the outside of the steering wheel. I think this was attributed to structural failure.
  • Intrusion into the occupant space in the foot area.
While the face-plant is troubling they didn't attribute any possible injury to this; their concern was more the footwell intrusion would likely cause lower leg and thigh injury. I'm thinking multiple fractures.
I don't think it's worth losing sleep over, especially given the spread of late model cars (all costing more) that have this in common. I think it will reduce the value of GEs a small amount. Probably a good negotiating point on 2013s.
Here's their summary
Structure
The driver's space was seriously compromised by intruding structure. Lower interior intrusion measured as much as 34 cm at the lower hinge pillar. Upper interior intrusion measured 31 cm at the hinge pillar. The steering column was pushed back 12 cm toward the driver.
Injury measures
Measures from the dummy indicate that injuries to the left hip and left lower leg would be likely in a crash of this severity and injuries to the left knee and right lower leg would be possible. Head acceleration from the instrument panel hit was low.
Restraints and dummy kinematics
The dummy’s head barely contacted the frontal airbag before sliding off the left side as the steering column moved 14 cm to the right. Additionally, the seat belt allowed excessive forward excursion of the dummy’s head and torso, contributing to the head hitting the instrument panel. The side curtain airbag deployed but does not have sufficient forward coverage to protect the head from contact with forward side structure and outside objects. The side torso airbag deployed.
Old Jan 25, 2014 | 06:11 PM
  #62
Brain Champagne's Avatar
I haven't seen any insurance data indicating that MT cars get into fewer accidents than AT cars. I'd expect the insurance cost to be a bit lower because the cars are a bit less expensive, but if anybody has info that MT cars are significantly cheaper to insure, post away!
Old Jan 25, 2014 | 08:01 PM
  #63
Wanderer.'s Avatar
I don't even think they ask if it's MT or AT when you get insurance though maybe it's just my company.
I don't think MT makes me concentrate any more than AT. Once it's all muscle memory you don't even think about shifting anyway. You just do it. I tried to not heel toe at a corner one time that I always do and tried to tell myself to just take the corner and downshift after and I couldn't do it LOL.
On the other hand I think learning to drive MT did make me more aware, but now I can eat a Big Mac talk on my phone and shift no problem, though I don't do it.
Old Jan 26, 2014 | 03:37 PM
  #64
j1nNju1c3's Avatar
I just read this and I agree:
IIHS Subcompact Car Crash Results: Let's All Calm Down
I still love my Fit
Old Jan 27, 2014 | 07:16 AM
  #65
RAH's Avatar
RAH
That's a good article. Thanks, I needed that - I've calmed down!
Old Jan 27, 2014 | 07:41 AM
  #66
CrystalFiveMT's Avatar
Yes. That's an article everyone should read. In fact, just go to the IIHS site and type a car in and see the results. It will calm you down more.
dizank
Oct 18, 2006 01:16 AM
cliu
Jun 24, 2006 11:41 AM
benfal2001
Jun 1, 2006 08:07 AM
accupix
Apr 18, 2006 12:01 PM
